Question about Mitsubishi WD-52628 52" Projection HDTV
I got a replacement lamp for Mitsubishi WD-52628. In order for it to work, I have to turn it on and off a bunch of times. Sometimes it just shuts off before the picture comes on and doesn't work at all.
  • 336 Answers
Hi,did you close the door cover? Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Check the fan
was running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on and the red light will blink.
Posted on Nov 18, 2009
The light showing timer blinks for a bit then stays on and the lamp light comes on and is orange i just got it and was wanting to know if its a easy fix
Posted on Aug 16, 2012
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Wd-52628 bad lamp or bad ballast?
you cant - unless you have another tv to test it in. May be a ballast or the cooling fan for the lamp is not working.
Feb 02, 2010 | Televison & Video
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
No video but have sound everything works except picture lamp has been replaced
Ballast Board or you have a defective Fan, if Fan stops running set will shut off.
Dec 12, 2009 | Mitsubishi WD-52628 52" Projection HDTV
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Lamp light is steady yellow. TV works fine otherwise.
Order another lamp and have it on standby as the steady yellow light is telling you that the lamp has outlasted the normal rated useage hours so your lamp will fail without warning at any time.
May 13, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Shut Down Message
The repair is to have the DLP engine replaced!!
FYI: The engine also can cause the set to shut down without any display or might even tell you the lamp door is open when it is not.
Feb 01, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Projection HDTV Logo
439 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
