Question about Zebra Printer 140-751-00000
Zebra 140xi111 plus printer printed my labels fine, then I switched to a duralabel with the same dimensions and now it skips a few and then I get an error message saying the paper is out...is there a setting that needs changed for the different label
Hello aperkins308,
I am with DuraLabel Tech Support and your printer does need to be calibrated for the stock you have loaded. All DuraLabel printers come with free lifetime tech support so please give us a call at 1-800-788-5572 or send us an email at support@graphicproducts.com
Posted on Mar 25, 2011
  • 96 Answers
Press the pause button and then calibrate. Probably have to calibrate between different label stock.
Posted on Oct 13, 2010
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
How do you clear the printer buffer on a zebra 140Xi111 plus
1. click on "start" select "run" and type "services.msc"
2. after open services windows select "print spooler" services
3. stop "print spooler" services
4. click on "start" select "run" and type "C:\WINDOWS\system32\spool\printers"
5. after open the printers folder deleted all the pending print jobs
6. restart the "print spooler" services and try to print now.
Aug 06, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
MY TLP2844 SKIPPING LABELS HOW CAN I FIX IT
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
Skips Bar Code Labels
It could be software related.  The best way to find out is to restart the computer where the labels are coming from.  Turn your printer off and back on again as well.  Run the program that loads the forms into the printer to print with.
Is the printer on an ethernet connection or is it connected to a computer?
Oct 21, 2008 | Zebra Z4Mplus Label Printer
Zebra Printer 140-751-00000 Logo
271 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
