Question about Nokia 6680 Cellular Phone
My 6680 just does not get any signal when it does have signal and i phone my number its as if the phone is off
I have nokia 6680 I I forgot screen lock code when I turn my phone on it asking for lock code so now how I can open it ?
How can you forget a code you set and have been using multiple times a day? The default code is 12345. If you 'found' the phone, perhaps it is still set to the default.
NOKIA 6680 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/nokia/nokia-6680/hardreset/first-method/
Hard Reset NOKIA 6680. First method: Power on your handset. Hard Reset NOKIA 6680. Then please press and hold * key + 3 key + Call button + Power button, until you see Nokia logo. HardReset NOKIA 6680; After that enter your lock code. * The default lock code is 12345; Now your phone will reset and restart.
www.hardreset.info/devices/nokia/nokia-6680/hardreset/third-method/ Hard Reset NOKIA 6680. Third method: Switch on your phone. Hard Reset NOKIA 6680. Next press Menu button and goto Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore -> Yes Factory Reset NOKIA 6680; Then your device will reset and reboots. That's all. See the Previous method!
www.hardreset.info/devices/nokia/nokia-6680/hardreset/second-method/ Hard Reset NOKIA 6680. Second method: Turn on your cell phone. Hard Reset NOKIA 6680. You should now type this code: *#7370#; Then press your lock code. * The default lock code is 12345; After that your phone will reset and restarts. Success! See the Previous method! See the Next method! How to Hard Rest NOKIA ...
Nokia 6680 hard reset
www.hard-reset.com > Nokia hard reset Apr 3, 2010 - Nokia 6680 hard reset: Press these buttons * + 3 + call + Power on your phone. Before the device is reset, you need to provide the lock code. The default lock code is.
Nokia 6680 Hard reset - How To Factory Reset
https://www.hardreset99.com/nokia-hard-reset/nokia-6680-hard-reset-factory-reset/ Feb 18, 2017 - Nokia 6680 Hard reset and Factory reset. Forgot your android mobile Password or PIN or Pattern, Here you can get recovery solutions for free.
NOKIA 6680 Hard Reset - IMEI.info
www.imei.info/hard-reset-1350-nokia-6680/ Are your looking for a way to make your NOKIA 6680 work faster? Do you wish to clear all of the data on your NOKIA 6680 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data (including settings, applications, calendars, ...
videos
nokia 6680 hard reset Google Search
Mar 24, 2018 | Nokia Cell Phones
Can i recover phone if accidentally factory reset my phone Nokia 6680?
If you go to your browser type NOKIA 6680- how to hard reset my phone and follow instruction . Nokia unlock code is 12345. hope this helps
Dec 22, 2015 | Nokia 6680 Cellular Phone
My 6680 phon no 3g signal.but GSM ok
how can u get iglu in rajasthan dear friend
Jun 27, 2011 | Nokia 6680 Cellular Phone
How to openline my phone nokia 6680.?from globe to smart?
you ill able to unlock your phone here http://www.wickedunlock.com/nokia-6680/rs11wp9/
They will provide the code when you enter your imei number,you just need to select your country and network provider
May 10, 2010 | Nokia 6600
HoW TO fix my 6680,it has no signal???plz
try check out for manual selection of network in your mobile if u get the proper signal then your work is done otherwise network ic might have been damaged u can get it done in nokia center or mobile repair shop
Dec 04, 2009 | Nokia 6680 Handheld
How to repair nokia 6680 when it has no signal?
Moisture can get to any electrical product , it forms on the circuit boards.
Take your phone and take out battery and leave the phone to dry in a WARM room for 5-6 hours, then try again.
Nov 18, 2009 | Nokia 6680 Handheld
Always sending failed
Does the phone has a signal bar? If it can make or receive a call?
*****If it is with good signal and can make a call. It is not the phone's problem.
2. Many cell phones can only work with GSM network. Please make sure that you are not using a 3G SIM card.
Click to check your SIM frequency: http://www.gsmworld.com/roaming/gsminfo or call your provider to confirm it.
*****After these actions, pls try the following instructions. It is only need to do some setting to get SMS.
**Turn on the phone, "setting"→"Restore factory settings" →enter the password:you'll find it on your user manual.
**Call your provider to get a SMS service center number for filling SMS setting. (you may get the number by searching it on the carrier's wesite)
NOTE: you might have to enter the number as +1(XXX)XXX-XXXX for gsm.
For instance, (+12063130004) should be +1(206)313-0004 (this is for T-mobile)
More suggestions, please click here to check: http://www.1010store.com/forum/viewtopic.php?f=2&t=174
Jun 13, 2009 | Nokia 6680 Handheld
How to openline nokia 6680.
is it blocked to a network, or you do not have it's security code?
if you dont have it's security code, post your imei serial number and i will generate a master code for it.
if it is locked to a network, post your imei number, and the name of the network it is locked to, and i will try my best to help you.
May 24, 2008 | Nokia 6680 Cellular Phone
Nokia 6680 Cellular Phone Logo
65 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
