Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
Screen too bright, have just got monitor from e-bay and there are no instructions on use.
    Brigadier General:
  • 10,406 Answers
Check all the buttons near the ON/OFF button.
One of the buttons will activate the OSD (On Screen Display).
The OSD controls everything about the monitor, including BRIGHTNESS and CONTRAST. Use the other buttons to move between menu-items, and to "select" one of the sub-menus, and to raise/lower settings, and to "exit" from a sub-menu to the main-menu.
Posted on Nov 18, 2009
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
Too bright
hi,
change the brightness button of your monitor. you can find that button on your monitor. it has a "sun" icon, then change to your desired brightness.
Feb 19, 2011 | Acer Computers & Internet
Need to reduce the brightness on the screen. I
You can down load user manual and read the instruction on how to adjust the monitor.
http://www.viewsonic.com/assets/027/7939.pdf
May 12, 2010 | ViewSonic VA1930WM LCD Monitor
No longer bright
you might have a busted ccfl lamps or defective inverter circuit, bring the unit to a shop for servicing...
May 07, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
HOW DO I BRIGHTEN UP MY MONITOR SCREEN?
hi,
you can adjust the contrast and brightness of the screen accordingly using the following instructions. Please select the right combination of brightness and contrast according to your desire.
  • Please check out controls in the bottom of your monitor, below the scree. I have provided the image below for your reference.
  • In this the fourth option is OSD menu. Please click on it and you will scoll down to options .
  • you can see options called "brightness and contrast". I have added picture for this too!
9b04c60.jpgOnce you go that page,use the menu to enter! then use the 2nd and 3rd button to adjust the brightness. Now your job is done.Please click on 1st button to exit. If you need more assistance in this, please write back to us. Please rate my solution as helpful!
Apr 02, 2010 | Acer AL1715 17" LCD Monitor
Computer brightness just dissapeared randomly and brightness and contrast is at 100% can still see the screen but just barely
If you have a laptop or, flat screen monitor; as, opposed to a CRT monitor[. your screen brightness is provided by one or, two tiny fluorescent tubes commonly known as a "cold cathode" these are powered by a circuit board known as an inverter board that is like the ballast in your office fluroescent light.
Just like the ballast aforementioned:The inverter board changes the DC power of the laptop or, flatscreen monitor to an AC amplified voltage to light the display.
If your screen shows a red color or, takes time to brighten or, flashes on and off or,flickers like a bad fluorescent light in your office This is most often the problem. You can purchase replacement parts fot the cold cathode and, or; the inverter board and find instruction on how to change these components online in the manual of your respective computer or, on e-bay on such sites as; laptoppartsdirect.com
Apr 23, 2009 | Computers & Internet
LG 19 in monitor
it would be helpful to know which monitor you have - each one is a little different... basically, you need to press the "menu" button on your monitor, use the arrow buttons (on monitor, not keyboard) to get to the brightness adjustment screen, hit set, then adjust with arrow buttons, and hit set again, then menu to exit.
Jul 14, 2008 | LG L1915S 19" LCD Monitor
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Jan 04, 2008 | Dell M782 Monitor
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
143 people viewed this question
Alun Cox
