I have a front load washer model no. 417.44142400. It was starting into the final spin when it exploded with noise and kept spinning very loudly. After I moved the cycle ahead and got it to shut off I was able to open the door. I noticed the stainless steel basket was pushed back away from the door with a half inch gap at least between the rubber molding and the basket. I hope that's enough info. Thanks, Dave
  • vettxman Nov 18, 2009
    Yes I think that is very likely what is wrong with it. Thanks Dave
  • Washing Mach... Master
  • 19,396 Answers
Hi.
You have collapsed either the drum bearing spider, or the pulley.
The drum bearing is built in with the shell, and is part pictured in the big circle, on diagram below. The pulley is part 26 on diagram.
Here the parts.
Shell/bearin
Pulley
The rear of the drum must be inspected to find and replace the broken part. If the pulley is OK, then replacing shell/bearing assembly is quite a challenging job, not for beginners.
Here diagrams and parts for your appliance:
If you want a quote on repair, then you can call the Sears number listed on the owners manual.
Let me know if you have more question.
Please do not forget to leave feedback.
thanks.
Posted on Nov 18, 2009
LG front load washer.Will not spin and makes loud grinding noise
what is your model number is then we can get started then to get your unit fixed all redy
Jan 22, 2013 | Washing Machines
In the final spin the washer is so loud you can't stand by it what is wrong with it
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer is making a horrible noise when it goes into the spin cycle. It sounds like it is about to explode.
The bearings on those washers go bad and the washer gets very loud during the spin cycle. It probably won't explode but for what it might cost to fix it you might want to blow it up yourself
Jul 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
