Question about Vacuums
Problem with small belt and beater bar spinning. Where to get replacement belt and what is it called model number. Thanks. Only 2 months old 5780-900 Hoover windtunnel cyclonic
  • 701 Answers
Here you can get a package of the belts you need. Also here is a link to the manual:
U5780-900 Belts
U5780-900 Manual
Posted on Nov 18, 2009
Beater bar intermently stops turning
It's likely that the belt is just slipping. Remove the bar and clean all hair, threads and other debris it collects in the bristles and around the ends. Check the belt for wear of the rubber; it may have teeth on it unless they were worn off from slipping. In that case you need a new one but save the old one for it's model number to purchase on line.
May 28, 2015 | Vacuums
Roller will not turn
Conmaur102:
I don't know what type of vacuum you have, but you should check the drive belt to see if it is damaged. Remove the sole plate (at the bottom of the head) and remove the belt and roller (called the beater bar). check the bearings at each end of the beater bar (they must roll easily and smoothly). If they are bound up, pull them off of the ends of the beater bar and remove the hair, strings, and fibers wound around the end of the beater bar. Lubricate the bearings with light machine oil, and spin them by hand until they spin freely. Reinstall the belt and beater bar, and reinstall the sole plate. While you are at it... check the hose and head to make sure they are not clogged.
Jan 06, 2013 | Vacuums
Z61 brush won`t rotate belt ok
Hartlepoolke:
Unplug the vacuum, turn it upside down and remove the floor plate so you can access the beater bar. Remove the belt from the motor shaft and remove the beater bar and belt from the machine. At each end of the beater bar there will be a small circular bearing. Carefully remove the bearings from the ends of the beater bar, and remove the collection of hair, carpet fibers and any other junk wrapped around the bearing mount studs. Grab an old pan... (something to wash the bearings in) and an old toothbrush. Scrub the bearings with the toothbrush dipped in rubbing alcohol, and attempt to spin the bearings by hand as you clean them. When the bearings will spin freely, dry them out, and put a drop of oil (preferably 3-in-1 or light machine oil in the bearing. Don't soak the bearing in oil, that will just attract more junk to jam the bearing. Wipe the bearings off and rotate them to ensure that they aren't ratcheting or siezing up. Check the belt to ensure that the motor spindle has not damaged the inside surface of the belt... If it has, a new belt may be in order. Reassemble the vacuum and you problem should be solved.
Aug 26, 2012 | Electrolux Vacuums
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
My beater bar is struggling to turn. actually, it appears as though it is the motor that is struggling, as it slows down when going against the pile and the motor labours so much that it frequently fails...
Replace the belt, they should be replaced every 6 to 12 months. A belt may look ok but may have lost elasticity and be stretched out. If your belt is a year or two old it may be an inch or so longer than when it was installed. A stretched out belt may turn the brushroll fine but when it is lowered onto the carpet the belt may slip rather than spinning as fast as needed to properly agitate the carpet fibers.
If the motor isn't spinning properly that could be another problem.
Oct 20, 2017 | Beam Industries 875 Classic Central System...
The belt broke on my vacuum, how do i change it. the vacuum is a eureka model number 3041
Remove the base plate. It is held with screws accessible from under the unit.
Inside you will see the beater bar and the belt.
Remove the beater bar. This is self explanatory once you see inside the power head.
Remove the old belt.
Find a replacement from your local dealer or online.
Replacement is the reverse of removal.
This is a simple job you only need a screwdriver.
Good luck, please rate this answer. Thanks.
Mar 27, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
The brush isn't spinning
the belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
Jul 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Belt burning
the beater bar probably needs to be removed & cleaned. the shaft & bearings get bound up with hair, string, etc.. with the belt off the bar, it should spin fairly easily. if it's hard to turn,(belt off) then it's bound up.
Jun 14, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
135 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
