Question about Brother MFC-8460N All-In-One Printer
Same as the one posted for the MFC8460.Message "No Paper" when the tray is full. It started doing that when it was less than 6 mos old. Playing around with it, tray in and out, cleaning rollers would fix it for awhile, but it does it on and off. Very annoying!
AvioriX
  • 689 Answers
SOURCE: Brother 8460N Laserjet
Hi
This is unfortunately very common issue about MFC-8460N, There are few steps you can try, Set to factory default (Reset), move the roller manually so sensor will detect new position or locate the paper detector and bypass it. There are many users have been complaining regarding the issue that you have, Before try the troubleshooting that i have suggested please do call the hotline of Brotherif you have ongoing warranty. Some cases Brother accepts their fault on this known issues and provide solution (can be free of charge). As an experienced expert I suggest you to contact Brother (1-800-276-7746).
If you cannot find any resolution please post further assistance.
Good Luck
Posted on Jan 27, 2008
execution372
  • 3 Answers
SOURCE: Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Posted on Mar 09, 2009
SOURCE: FEEDING PROBLEMS FROM PAPER TRAY
Brother MFC7820N Paper Feeding Kits are available at Precision Roller:
http://www.precisionroller.com/brother-mfc7820n/products.html
$25.75
Paper Feeding Kit - Kit contains: Pickup Roller Assembly, Separation Pad - Genuine Brother Kit
For Use In: Brother MFC7820N
and also Brother DCP7020, Brother HL2030, Brother HL2040, Brother HL2070N, Brother intelliFAX 2820, Brother intelliFAX 2920, Brother MFC7420
Mfr Part #: LM6291001, LM4581001
PR Order #: E0823
Annette G
Posted on May 18, 2009
  • 13 Answers
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist PhillyCopiers.com 215 364 3774
Posted on Apr 15, 2010
reyjoshua07
  • 1157 Answers
SOURCE: Brother MFC 8460n paper pickup
Hi tkennedy0720,
Please follow these steps to assure you have made sure there is no jam.
1. Press the cover release lever to open the front cover.
2. Take out the drum unit and toner cartridge assembly.
3. Open the back cover.
4. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5. Using both hands, gently pull the jammed paper out of the fuser unit.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back in the machine.
8. Close the front cover.
9. Press the cover release lever to open the front cover.
10. Take out the drum unit and toner cartridge assembly.
11. Hold down the lock lever on the right and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
12. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
13. Put the drum unit and toner cartridge assembly back in the machine.
14. Close the front cover. Pull the paper tray completely out of the machine. Use both hands to slowly pull out the jammed paper.
15. Press the cover release lever to open the front cover.
16. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
17. Put the drum unit and toner cartridge assembly back in the machine.
18. Close the front cover.
20. Put the paper tray firmly back in the machine.
21. Take out any paper from the ADF (automatic document feeder) that is not jammed. Open the ADF cover. Carefully pull out the jammed document to the left. Check for and remove any small pieces of paper stuck in the machine. A small piece of paper stuck in ADF will cause a document jam.
22. Close the ADF cover. Press Stop/Exit. If the Document is jammed under the document cover. Take out any paper from the ADF that is not jammed. Lift the document cover. Pull out any jammed documents to the right. Again, carefully check for and remove any small pieces of paper.
23. Close the document cover. Press Stop/Exit. If the Document is jammed at the output tray. Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
24. Press Stop/Exit. If the Document is jammed in the duplex slot (only for machines which support Duplex printing). Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
25. Press Stop/Exit. Make a Copy to test. Before placing your document(s) in the ADF verify the error message "Document Jam" in no longer displayed on the LCD. If the error message continues to appear on the LCD, please contact Brother Customer Service from "Contact Us". Verify the ADF document support (located on the top of the ADF) is pulled out. Verify the document(s) are between 5.8 to 8.5 in. wide and 5.8 to 14in. long. Make sure the documents are inserted face up in the ADF, top edge first. The ADF can hold up to 50 pages and feeds each sheet individually. Use standard 20 lb (80 g/m²) paper and always fan the pages before putting them in the ADF.
Note:
DO NOT use paper that is curled, wrinkled, folded, ripped, stapled, paper-clipped, pasted or taped. DO NOT use cardboard, newspaper or fabric. Make sure documents written with ink are completely dry. Adjust the paper guides to fit the width of your documents. This ensures the document(s) will feed straight, preventing jams. Make a copy listed below:
For MFC users :
Press Start.
For DCP users :
Press Copy located below the LCD and then press Start.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 06, 2011
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Why does my printer say there is no paper in the tray when it is full?
from what u did I would look for a broken paper sensor.
It could also be a ripped paper hanging the sw.
it might also be that somehow the operating tray got changed in the config - if u have multiple trays or manual feed
Mar 03, 2015 | Brother HL-4070CDW Printer
"add paper" message but full of paper
jaha par paper laga rakhe waha ki paper tray select karo
Aug 01, 2012 | Toshiba 2060 Copier
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
I've had this happen to my scx4521f a few times. I think I had too much paper in it. Or maybe it was poorly loaded paper. Take the stack of paper out and turn it around so you have no dings or dents on the inward facing side. You need to make sure that the paper is stacked evenly. Good luck. And now I will post my problem.
Apr 09, 2008 | Samsung SCX-4216F All-In-One Laser Printer
I get a load paper message when paper is loaded
Probaply some paper or obstackles stuck at PE (paper empty sensor) and that could be hard to fix it cuz you may need to pull apart the printer. However, if it is 6 monthsold, warranty covers this problem.
Feb 08, 2008 | Brother MFC-7820N Laser Printer
Keep getting "out of paper" error message
Unfortunately this printer and alot of others like it have a very poor paper feed mechanism. I am finding that the (1) small pickup roller that is used in this and other machines like it is failing (not picking paper) prematurely or faster than i think it should (this is looking at page counts on some of these machines). We have been disassembling them and rubber restoring the pickup roller which fixes the paper jam/paper out errors.
Inkworks
Dec 14, 2007 | HP PSC 1210 All-In-One InkJet Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Brother MFC-8460N All-In-One Printer Logo
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
