Question about Dynex (TE685AVR) UPS System
Dynex TE685AVR I have had this surge surpressor for about 5 years. The green light is still on but when the electric power is interrupted, it no longer provides power to my computer allowing me to shut down safely. Is there anything I can do to fix this---other than buying a new surge supressor.
  • 2 more comments
  • clovergirl Jan 12, 2008
    Thanks for your help. I took my UPS to Best Buy and the guy from Geek Squad tested the plug-ins. He determined that the 3 surge protector plugs were working, but the 3 surge/battery back-up plugs had some sort of electrical problem. I ended up buying a new UPS and will use the old one to protect an extra TV and DVD player that I have. I still may try replacing the battery and see what that does, but it's possible that my old UPS fielded too many lightning strikes or power surges. I appreciate you taking time to answer my problem.
  • bk0822 May 17, 2008
    No power to the UPS. My modem was plugged into this unit. I couldn't get on-line from my laptop, when I went to take a look, there was no power to the modem. Will try to replace the battery.
  • Anonymous Jun 06, 2008
    my problem is the surge side the light is off but the push button switch was downonly baterry side working no power on surge side?
  • flyhal Jun 30, 2008
    System drops off line when lightning hits. Battery show zero charge but working normally. Sometimes takes several minutes before resets so computer will work again.
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
The model of the battery is a WKA12-7.5F2 and can be purchased at: http://www.replacementupsbattery.com/Product_pages/wka12-75f2.html.
Posted on Jul 15, 2008
    Scholar:
  • 95 Answers
You need to replace the battery in your UPS. I went to the mfg. to find your model but i was unable to find the model you had posted. You should be able to take the battery out and go to a retail place like battery plus to get the battery you need. If not you may be able to get it from the manufacturer.After replacing the battery you should fine.Here is a link to the web site.
http://www.dynexproducts.com/c-6-surge-protectors-and-upss.aspx
Posted on Jan 12, 2008
The wireless is ok but if theres black out when the power is back my wireless is not working
First I suggest you get a UPS and attach ALL your devices on battery backup. Power surges/power interruptions could be detrimental to your electronics. After a Power Interruptions ALL your devices may have to be rebooted one by one, allowing each to selftest. If you live where the power goes off often or electrical storms are common, it's crucial to use Surge protectors and a Universial Power Supply.
Apr 22, 2013 | ASUS RTN10 wireless router
No matter what fax number I dial, I hear the cannot be reached as dialed message. I have one verizon phone line, with verizon DSL running off of the same line. My phone line is okay, because I can reach...
It is probably the same problem I just had with mine through Comcast. All I was getting was a not answered message no matter what number I dialed. I had the telephone line running through a surge surpressor that had one line running in and then two lines running out. I had been hooking up my fax through one of the two out lines. When I switched it to the main line and not through the surge protector everything worked fine.
So if you have any splitters or surge surpressors on your line - switch to the main line and see if your problems does away like mine did.
Have a great night!
Jun 20, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
The green light cimes on but there is no Picture or Sound on my dynex 32'' tv
Sounds like your power supply is shot. Possibly a fuse blown. If its connected to a surge suppressor try plugging it straight into the wall socket.
Feb 28, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
My dynex tv will not come on seems to be stuck in standby mode.
It sounds like the main power supply is trying to startup but failed because there is short circuits or the main power supply is bad. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Dynex DX-LCD37 TV
I have a Te685avr that has been working fine. It
You might have to replace the fuse in the unit it should be located near the back. without a good fuse in the unit than nothing will happen
Oct 21, 2009 | Dynex (TE685AVR) UPS System
Dynex Te685avr backup battery doesnt work
The sealed batteries in these last about 6 years. You are correct in thinking that you may need a new one. Very easy to install. Here's a supplier of these: http://www.batteryinternational.com/dynex-te685avr-ups-battery-ups-batteries-f1.html
Jun 02, 2009 | Dynex (TE685AVR) UPS System
Dynex TE685AVR - wiring problem light on
yes first disconnect the pin of load then switch off ups then switch on check ac voltage at output if comes and disappears when load is connected then battery is faulty it shows voltage without load but disappers when load is connected replace battery
Nov 09, 2008 | Dynex (TE685AVR) UPS System
Jun 26, 2008 | Dynex (TE685AVR) UPS System
Computers & Internet Logo
436 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
