Question about Nikon D60 Digital Camera
Blue tinge to photos
Sometimes when i take a picture using the d60 the picture comes out with a blue tinge, whihc is darkest at the bottom and getting lighter up the picture. Any ideas why?
If i switch the camera off it appears to solve the problem for a while
5 Suggested Answers
SOURCE: camera not recognised on computer so unable to transfer photos to
Try reloading drivers software that came with the camera.
Posted on Apr 24, 2009
SOURCE: Blue photos on Nikon D60.
Check your white balance or wb button.
Posted on May 25, 2009
HyeProfile
  • 35 Answers
SOURCE: Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
Posted on Jul 10, 2009
  • 1566 Answers
SOURCE: Have a Nikon D60 and after I take a photo, I get
You need to press the Disp/Display button to remove the settings on the display.
Posted on Sep 22, 2009
Testimonial: "Also had to use the multi selector to get rid of it. I now understand the process. Thanks"
HP photosmart 6510 prints pictures with blue tinge
Try doing a head cleaning, maybe there is the problem, let me know.
Mar 24, 2013 | HP Photosmart 6510 Wireless e-All-in-One...
Photos are coming out with a blue tinge. Out on the harbour where the water is a greeny blue and the sky grey to blue, all photos seem to have a blue tinge. ISO is 100. Photographed some trees and these...
Check the white balance settings. If the photos where taken in the high midday sun this is the high UV content in the air. Set you white balance to Cloudy and see what that does. Also fit a UV lens to the front of the lens if haven't already.
Nov 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
IS THERE A SPECIAL CARTRIDGE FOR PHOTO PRINTING. MY PRINTS COME OUT WITH A BLUE TINGE TO THEM my printer takes No. 32 black and 33 colour..
Sir,
Your problem is not of specially cartrigde but what you need is a special Paper which is made to print Photos and other colour full pictures. If you see is not this problem then there is chance that your cartridge is leaking from blue color point as there are three inks in color cartridge Red,Blue and yellow , than you need to replace you colou cartridge with new one .
Aug 28, 2009 | Office Equipment & Supplies
May 04, 2009 | Nikon D60 Digital Camera
Philips Magnavox 55P8288A Green tinge over entire picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Mar 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
When takining photos all the shot recently appear with a blue tinge. Before taking a photo, the screen displays the following; 'P' left hand top right corner. light bulb left hand side and along the bottom...
You are in Program mode most likely, with some sort of white balance setting that is not sunlight. Go into menu and try to change back to auto mode,or reset all or default. Sometimes removing the battery for 12 hours gets it back into default mode. the HQ is just the resolution that it is shooting in.
Apr 22, 2008 | Cameras
Printing Problem With My HP cp1700D Color InkJet Printer
First clean the cartridge and then go to toolbox and give test print.
Feb 17, 2008 | HP cp1700 Color Inkjet Printer
All scanned documents have blue background.
You have to take the machine to service partner who can be found on the brother homepage of your country.(www.brother.com)
The scanner needs calibration which can only be done by service personel.
Dec 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Nikon D60 Digital Camera Logo
18 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
