Question about HP Pavilion a305w (DM181AR) PC Desktop
How do i set a bios password on a hp pavilion a305w? ive tried pressing esc and it takes meto the bios setup but there is no security tab....
  • 65 Answers
Look for someting in the bios called administrator password
Posted on Nov 18, 2009
  • atyab99 Dec 07, 2013
    I've done it, bt its of no use. Administrator Password is enabled but PC is logging on without prompting for Password.
Boot hp pavillon zd8000 with usb not possible?
Boot hp pavillon zd8000 with usb is possible.simply plug the USB flash drive with iso and reboot, then press F10 navigeyt Boot Order Mark hard drive, hit enter, Highlight your usb and press F6 so usb was on top of the press F10
May 15, 2012 | HP Pavilion zd8000 Notebook
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
My girlfriends Hp Pavilion A305W powers on then automatically powers off after it show a brief error message but also says F1 for startup. Should i press F1 and continue diagnosis?
Most probably your system is not getting your BIOS settings from your mainboard due to CMOS battery failure.
Check your CMOS 3.0v battery & replace it. Then reconfigure your BIOS settings from the CMOS setup.
Hope it helps
May 28, 2011 | HP Pavilion a305w (DM181AR) PC Desktop
Installed new bios for windows 7, not working,on start up, computer locks up, able to unlock- but didn't happen with original bios. Looking for old bios to re install sholder012001@yahoo.com
o open the BIOS Setup screen: Reloading the BIOS default settings To reload the factory BIOS settings to the setup default:
  1. Press the F5 function key.
  2. Select Yes or OK.
  3. Press the Enter key.
  4. Press the F10 function key.
  5. Select Yes or OK to save the defaults.
You can also complete the following steps to reload the factory BIOS settings using the menu:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults.
  3. The system prompts you to load the optimized setup defaults. Select Yes or OK and press the Enter key.
  4. Select Exit Saving Changes.
  5. Press Esc and then press Enter to exit Setup.
Please don't forget to rate this if it fixed your problem. Four thumbs up is basically what means your problem was solved. Anything less means your problem was not solved. Not sure people here understand that as far as how we get rated.
Jan 15, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
Was just wondering because i tried one method but didn't work for me on my hp pavilion a305w, but my question is, can hp pavilion a305w boot from usbs?
unfortunately the hp pavillion a305w bios would have to support it. you would have to go into the bios on set uo and select that boot option. but unfortunately they do not have the option to boot from usb
Jan 08, 2011 | Computers & Internet
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
Finger print lock password software
Log onto machine as local administrator
Launch HP ProtectTools Security Manager for Administrators
Bios Configuration -> Security
Fingerprint Reset on Reboot - Enable.
Reboot
Esc for Bios Setup
Choose Bios Option
Press F1 accept a reset of the password .
Nov 26, 2010 | HP Pavilion dv6000z Notebook
How do I program my latitued lap top so it gors directly ine to the windows sart up , instead of having to enter a pass code to go thru the bios program. Once I eneter the bios pasword it will activate...
It seems that the Dell is not publishing the BIOS reset info online. You can try following the below steps once. ( Article ID: 184659)
During the initial boot of a computer the BIOS supplier will be displayed. If OEM logo splash screen is displayed, press ESC key to see the boot up information. Press the Pause/Break key if text displays too fast.
In the BIOS window, select Security tab and delete the BIOS password.
Jul 04, 2010 | Dell Latitude D610 Notebook
HP Pavilion a305w (DM181AR) PC Desktop Logo
79 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
