Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Candy cpca240ffk compressor running.
Ive recently swapped a working 20 years old fridge freezer not a candy for a 2 year old non working candy.The compressor comes on for about 5 seconds and then the relay on the control board clicks turning the unit off .still does this even if I unplug the thermocouple..anyone got a circuit diagram for the unit.
    President:
  • 1,314 Answers
I don't have a diagram but im familiar with that problem its either a bad relay on the compressor a bad thermal over load in the relay box mounted on the compressor terminals or a bad compressor don't know where you live im in usa here you can get an after market relay with a start capacitor and if its not the compressor will fix the problem
Posted on Jan 10, 2008
My candy fridge freezer fridge part is freezing! the light keeps clicking on and off. The food is either frozen or warm. never cold as usual. I would like to know if i need to buy a new one. It is 7 years...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 30, 2011 | Candy CPCA240FFK Bottom Freezer...
In my candy fridge freezer the freezer is working ok but the fridge isn't working at all. Please advise
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Candy CPCA240FFK Bottom Freezer...
Candy Fridge Freezer CVC 324AK approximately 5 years old which is running all of the time and freezing up
If your fridge is running all the time and you are not hearing it shut off you must first of all check on the thermostat, the lines to the thermocouple. Then start the fridge and check if the compressor stops, if not shut off and reduce the settings on the thermostat. if the fault recurrs then try to change the thermostat and see byt setting the thermostat low if the compressor shuts off. Also check for the wiring to the timer and the allied circuits. I amsure you can get to this fault, take help if it is beyond you, but keep this advice in mind. Good day
Aug 11, 2010 | Candy CPCA240FFK Bottom Freezer...
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge running light(green)flickering
hi,thanks for your e-mail i couldn't find a solution and the fridge was fairly old we bought a new one,cheers,vic.
Nov 30, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy Futura Fridge Freezer
very simple fault - drain hole is blocked. push something flexible down the hole till it clears and water flows away freely
Aug 28, 2008 | Candy CPCA240FFK Bottom Freezer...
Frost free fridge
Check and set both temperature adjustments, one for freezer should be no more than 1/2 and the refrigerator also as a starting point.
May 05, 2008 | Candy CPCA240FFK Bottom Freezer...
Lights out & fridge freezing after switching off and moving it
a servicing expert told me when bulb goes can cause a failure on control board. others confirmed control board failure occurs often and the only other part that goes is the compressor (and thats really expensive to repair!). control boards can be fitted yourself - mine cost about £50.
Mar 04, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge freezer not reaching operating temperature
maybe its time your fridge to go to the service center. 5 years is a long time yaknow. have them check for the freon as it might have runned out.
Jan 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
224 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
