Question about Brother MFC 4800 All-In-One Laser Printer
The scan comes out as a solid black image both in the preview and in the actual scan.
  • 134 Answers
This is a preview from a related model, you must set the profile to photo and the color format of your reference. Hope this helps.
Posted on Nov 18, 2009
When scanning a color picture it comes through in black and white what am i doing wrong?
Change the Options on your HP Scanning Software to Scan in Colour or Else:
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Thanku.......
Good Luck!@@!
Sep 23, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
Black Image
Is the lamp itself working and turning on? If so then it is the optics that actually scan are bad. or the board that controls them. How long have you owned the scanner?
Thanks,
Lee
Aug 18, 2008 | Visioneer OneTouch 5300 Flatbed Scanner
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    How do I scan a picture and email it?
    Hi
    You can start a scan from your computer or from your HP OfficeJet.
    to scan an original from your Windows computer
    1 Load your original either on the glass or in the automatic document feeder
    (ADF).
    2 Press Start Scan.
    A scan of the original appears in the HP Preview window.
    3 In the HP Preview, you can edit the scanned image. When you have
    finished, click Accept.
    For more information about making changes to an image during the
    preview, see adjust an image during the preview in scan pictures and
    documents in the HP Photo & Imaging Help for more information.
    The HP OfficeJet does a final scan of the original and sends the image to
    the HP Photo & Imaging Gallery.
    If i helped you pls vote me
    Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
    Scan image is not its actual size
    Check the following. Open your HP solution centre, settings,scan settings, Scan picture settings or scan document settings. on the right hand side youll get scan pic setting again and check the setting in that box. Check also settings print settings, printer settings, check here for print or scale size
    Aug 15, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    Printer prints solid black block at end of page
    You have to replace the white tape, connecting the scanner sensor with the printer PCB. 26642b8.jpg
    Nov 23, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
    Negative Scanning Problem Using Epson Scan Software
    Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
    Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
    Scanned image only prints in black and white
    it's tricky / annoying:
    you have a preview ...
    you have some of the (3) images checked
    but also you have some of these images selected (blue outline)
    now:
    when you select (I don't mean the checking) an image you'll have to set the scanning params
    again - or check them ...
    if you select an image, and then set the params (like "color"), your scanned image will be in color
    also resolution is the same way ..
    especially after crating preview .. it'll be set to 300 Dpi
    so after seecting one for scanning - check the resolution too :)
    jepe
    Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
    Solid black image with flatbed or adf
    This particular scanner may not run to NTFS instructions.
    Check Windows Help in my computer- for program Compatability
    and try to reset the software to run as Windows 98 - it may work.
    Dec 07, 2007 | Microtek ScanMaker 5950 Flatbed Scanner
    Brother MFC 4800 All-In-One Laser Printer Logo
    186 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
