54cm Goldstar tv Model no: CZ 20A 90Y
Zener Diode in power supply blown away near IC STR S6707. Need to know the value. Its placed on ZD 811.
Ordinary zener diode
Posted on Mar 28, 2010
Please help about the two diodes with color red, red, gray located in power supply unit. The IC switching voltage regulator is STR F6656.What is this diode? It is Zener?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Power supply circuit diagram using STRF6656 is given. There are many TVs using this circuit in the SMPS. You can get details there. Type in the STR number; in the search box at the top right of the display window; to get gathered related posts.
Jul 17, 2015 | Televison & Video
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
S6707 regulator power supply does not work
Check all the associated components, resistors, zener diodes etc: before replacing it with a new STR. If you wish to get the schematic and some other details, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 27, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
My hitachi 29in ctv power supply 110vac had a problem on zener diode will blown if we switch on the tv. what spare parts to change so that the power supply zener diode will not blown again and the supply...
The secondary output voltage comes out from is more than it should be there. That is why, the protection zener diode blows off, as soon as you switch ON the set. First find and repair the power supply regulator, for correct output voltage. Refer its repair book for details. After repair include the zener diode in place. OK.
May 08, 2012 | Hitachi Televison & Video
I have sony J21mn11. problem not power on only red lit led only.i check all the components on the power supply area and horiz. output D1878 all are good. there is power IC STR S6707 on power supply area. i...
If you have a digital tester or analog try to check the voltage reading from the power supply if high or low or no supply.Check first following voltage location and section. * Check the AC voltage from ac cord to fuse and before the bridge type diode. * Check the DC voltage after the bridge type diode.if normal voltage. * Then check the voltage into the filter capacitor to regulator ic.the power ic.If theres a input voltage in the power ic,check the output voltage going to harizontal output.If no output the problem is you power output.You need to replace it.
Jul 12, 2011 | Sony Televison & Video
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No video, no audio, red light on in front of TV
Excellent visual acuity technique!! I try to teach that procedure.
IC F6629B is probably shorted and at least one other part will
be open, possibly a zener diode,a fuse,a resistor or combo.
The service diagram would help.Be sure to use OEM first quality
parts.Let me know if you need more help.
Sep 25, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Televison & Video Logo
255 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
