Question about Huffy Cycling
Can not get it to shift gears on the handle bars
    President:
  • 1,138 Answers
Here is a link to a site with lots of help with pictures:http://www.parktool.com/repair/byregion.asp?catid=53 Please let me know if this helps.
Posted on Nov 20, 2009
3 Suggested Answers
Coachphil
  • 347 Answers
SOURCE: there are gear shifts on
I strongly suggest taking the bike and your son into a bike shop. They will be happy to show him not only how to shift the gears, but why and when. Also they may even throw in some maintenance tips.
The easiest settings will be labeled 1 and the hardest the larger number. if you were too look at the bike where the chain is, the gears that are closest to the frame are the easiest and the ones far away are the hardest. In the back this means the largest gears are the easiest in the front they are opposite, smallest gears are the easiest.
There are a number of good books and many free instructional videos on youtube that show shifting principles. The biggest issue for 10 year olds is whether they can reach the levers comfortably.
Posted on Apr 23, 2011
dunnbiker
  • 8546 Answers
SOURCE: Dymacraft Mod 8575-83D How do handel
Before you go and disassemble them and make things worse, get a grip (pun intended) on the derailleur adjustments.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Search engines can instantly answer high level questions like "how things work", usually with videos.
While you're at it, search for "how to shift a mountain bike".
Posted on Jun 16, 2011
Why are my gear controlls on my handle bars stiff and hard to move
COULD BE RUST IN THE CABKLE, OR A FRAYED WIRE
Mar 20, 2015 | Cycling
What is a derailler
A derailleur is a device that assists in shifting the gears and moving the chain from one chain ring to the next. This is generally achieved by the use of a cable and a shift lever that is attached to the handle bars.
Jul 11, 2014 | Shimano Brake Cables Atb Mountain Bike...
Dymacraft Mod 8575-83D How do handel bar gear shift operators work. Both of them are defective (will not shift gears) and I would like to know what is inside the handle bar gear change mechanism before I...
Jun 16, 2011 | Dynacraft Cycling
Key stuck in ignition
We just had this same problem today!!! We have a 2006 Ford Focus and the car would start and we could still drive it, but the key locked in the ignition and would not come out. We tried everything, but what worked was to move the black sleeve (has three plastic rings at top close to handle bar) around the gear shift handle bar, up. It was pushed down about a half inch and it took some pressure to pull upwards, but once we pulled the plastic black sleeve around the gear shift handle bar up, the key came out! Easy as pie!!! Saved hundred of dollars! YAY!!!
Aug 10, 2010 | Ford Fusion Cars & Trucks
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
Shifter hard to turn
Take it to a Bike Shop and have them check the shift cables for rust and kinks.
May 29, 2010 | Cycling
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
My bike has a problem shifting. It doesn't want to stay in the lower gears and wants to jump gears when I shift.
check the gear adjustment at the handle bars. you may need to tighten the shifter up a bit.
Sep 20, 2009 | Cycling
Having problems with gears on my Apollo LSX 1.1 mountain bike
Sounds a lot like cable stretch. Have a local bike shop replace all the cables and do a derailleur adjustment. Costs is usually under $40 complete.
Apr 17, 2009 | RTO Bicycling Complete Guide to Bicycle...
Cycling Logo
37 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
