Question about Zanussi WDA1055W Front Load Washer / Dryer
My ZWD 1662 W front load washer drier is not drying. The time of drying also seems to be very short no matter the setting
  • 95 Answers
Faulty bi-metal units one is high heat other is low both must be changed as they come in pairs
Posted on Nov 18, 2009
ZWD 1662 W start/Pause button flashing but not connecting to programme
hi,if this is the washer drier type try this,unplug m/c!! take lid off and locate the four connections to the drier unit near the back panel.some connections will be double tagged others single tag.disconnect all four connections and let wires dangle down a bit ,they shouldn`t touch anything.plug m/c back in and try a program such as drain and spin,and then if ok try a fill.the reasoning behind this is that the drier element goes faulty and gives a false reading to the control pcb.if this is successful ,replace the drier element.another option if any of that doesn`t work ,check carbon motor brushes.
Jul 22, 2014 | Washing Machines
I have a zanussi washer dryer ZWD 14270w and the dryer is taking hours and hours to dry anything..help!
Not sure how full the drum is when you are using the dryer, but I have this appliance and it works best if the drum is half full. If the drum is full, things don't dry properly because the air can't circulate.
If that doesn't work I'm out of ideas!
Oct 24, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
Tm545 drier
If there are just two terminals (which is usual for drier elements), it doesn't really matter - just put them on whichever way seems tidiest.
If there are three, then you need to make sure that the green wire with the yellow stripe goes to the metal body of the element (usually via the fixing nut). The other two go to the main terminals in whichever order feels tidiest.
A.
Jan 04, 2009 | Tricity Bendix AW1000W Front Load Washer
Drier Motor
Disconnect the vent at the back of the dryer and dry a load unvented to make sure you don't have a clog in the vent line too the outside causing an air flow restriction, if still not drying check and make sure the blower wheel that circulates the heat inside the dryer isn't broken.
Jul 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Jul 20, 2008 | Washing Machines
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
Neff washer/drier
soap drawer is just a slide fit - give it a good yank. for the dryer, take the top off and there should be a mainifold across the top with stats mounted on it. one or two may be re-settable stats ie have a little button in the middle which press to reset. if this works, cause of stat popping out is usually a lint blockage in the dryer manifold
Apr 28, 2007 | Neff V4380X0 Front Load Washer / Dryer
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Zanussi WDA1055W Front Load Washer / Dryer Logo
304 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
