Question about Microsoft Windows Vista Ultimate Edition
MY HARD DRIVE FAILED, WITH HELP I HAVE FOUND A SUITABLE REPLACEMENT BUT I NOW HAVE NO OPERATING SYSTEM. I HAVE THE ORIGINAL PRODUCT KEY. CAN I GET A NEW DOWNLOAD FREE OF CHARGE?
  • Alun Cox May 11, 2010
    Not legally, you should've made a backup disc when you first purchased your PC/Laptop. (You'll now also need all your drivers as well!). As you do legally own a license then downloading a torrent of Vista would be a grey area which you could do or borrow a disc from someone else.
  • 79 Answers
You need to get recovery disc, from the manufacture you just own laptop, if it came one, then you lucky. If not call support..try ubuntu, is free
Posted on Nov 19, 2009
    Guru:
  • 1,738 Answers
I would go and buy you a copy of windows, prefer windows xp because of better driver support. It sound like you had windows on your hard drive and when it crash you lost your windows copy. This is if you had your own windows copy and the drive crash again this won't happen again.
Posted on Nov 18, 2009
If I replace my hard drive do I have to re install windows 7 from using my product key sticker which is found under my laptop ?
Yes you have to reinstall Windows 7, because the operating system resides on the Hard Drive. You can certainly try using the product key under the laptop. I also believe that if you have the recovery media and want to reinstall on the SAME computer with a different hard drive it should work. It is possible that you will not have to register again.
Dec 10, 2013 | E-Machines emachines (emachinees) CD-ROM...
Operating system not found
An Operating System Not Found error typically crops up in the start-up cycle for a computer, before Windows has had a chance to load. The computer is letting you know that there is a problem with that normal start-up cycle, and it has come at a point where it would be expecting Windows to take over from the BIOS--the software built in to your computer's motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd \ cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error. If this fails to fix the problem Insert the Windows install disk for your version of Windows and reboot the PC. With the computer unable to find the operating system on the hard drive, it may skip automatically to the next possible boot device, which should be the CD or DVD-ROM drive. Some systems may be configured to boot to that source first, and others may not be configured to roll over to the next device at all. When in doubt, there should be an option to select boot device when the computer is first powered on (the F12 key on most Dell computers) and you can boot straight to the optical drive from there. Press any key when prompted to boot to the install disk, then follow the on-screen instructions. You'll want to try to perform a repair on the existing Windows install, which you will get to by first selecting a new install of Windows. Select to install a new operating system, and the install package will look to see if Windows is already installed. If it finds the existing install, the installer should give you a chance to perform a repair of what's currently on the hard drive, replacing corrupted files with clean ones from the install disk. If the Windows installer does not detect an existing Windows install on the hard drive, then the hard drive itself may be at fault. Replace the hard drive and repeat the first few steps to install Windows from scratch. The original hard drive is likely corrupted or otherwise broken, and may not be recoverable at all, outside of an expensive, third-party data retrieval service. Hope this helps
b>
Dec 11, 2012 | Microsoft Windows Vista Home Premium with...
Operating System not found
Im assuming you have an installation or a recovery disk
hope this helps
Oct 11, 2012 | Sony Vaio Pcg-Fx140...
The hard drive on my laptop is not working. I have been told i need a new hard drive. Windows 7 is on the broken hard drive. the new hard drive wont have windows 7 on it. The laptop doesnt have any...
If the company that made your laptop is replacing your hard drive, then they will reinstall the operating system for you. If not, things will be a bit more difficult.
Look on the bottom of your laptop. There may be a sticker that indicates what version of Windows your laptop has (had). If there is, look for something that looks like a product key on that sticker. As long as you are using the same laptop and only replacing the hard drive, that product key should still work if you re-install Windows. As for finding a disk, you will have to search around the internet for a Windows 7 installation disk. This should not cost nearly as much as buying a completely new operating system disk with the product key.
Mar 28, 2011 | Computers & Internet
I have acer aspire 5735 notebook. I got new hard drive. so pls tell me how can install original operating system on the new hard drive and how can data transfer old hdd to new hdd. I have product key...
If your old harddrive is operational the best way to get your new drive loaded is to get a cloning program clone your new drive all operating system files will be transferred to new drive,install it and you should have everything old drive had
Jan 27, 2011 | Acer Aspire 5735 Notebook
Hp Pavilion 6701 desktop with ME. Installed Xubuntu OS and removed ME. Want to reinstall ME but recovery disc won't work.
Hard disk needs to be reformatted--start machine and press correct key when "setup" appears in first dialog. Remove hard drive in first screen, then reinstall. Restart computer, should now say: "operating system not found". You need original Microsoft OS disk to reformat drive and reinstall ME. All previous information on hard disk will be lost with this procedure. Recovery disk is used with original OS before Ubuntu. If you don't have original MS disk, suggest going to XP.
Jul 06, 2009 | Computers & Internet
Operating system disks
If it is a new hard drive, you can install any OS you want. You do not have to use the original version of windows (etc).
Jul 05, 2009 | Microsoft Computers & Internet
Oops---virus may have destroyed the boot sector on your hard disk. Is there a CD in the optical drive, or a floppy in the floppy drive?? If so, remove before booting. If that's not the issue, you need to reinstall the operating system.
As far as original discs---perhaps you can get replacements from Sony if they still support the laptop?
Mar 26, 2009 | Computers & Internet
Software purchase
Hello dazz_hammer,
You can put up to Windows XP. If do, I would suggest to add memory and bigger hard drive.
Or if the pc has Windows Product Key Tag, and what ever the operating system it indicates then you can re-install that operating system.
Hope this helps and good luck.
Jul 27, 2008 | Dell Latitude CPX Notebook
Os not found
Operating system not found indicates that the system is not seeing a bootable device. Possible causes are:
1. Hard drive not detected due to loose connection. Reseat the HDD.
2. Hard Drive is failing/Failed. Replace HDD
3. System has a floppy drive and a diskette in the drive, remove diskette, reboot
4. Hard drive not in boot sequence. Reset BIOS to defaults
Jun 22, 2008 | Acer Aspire 5050-3242 Notebook
Microsoft Windows Vista Ultimate Edition Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
