My speakers were on but would not play any sound. I removed the fuse and then put it back in and now the speakers will not turn on
    Problem Solver:
  • 15 Answers
Put you fuse back correctly and check fuse is ok or not and install your sound driver's if they are installed so go to control panel and then go to sound option and click on advance and chose your speaker like 5.1,4.1 or any other you know which 1 and then click apply and then check your sound that's all
Posted on Nov 18, 2009
Jump started a car, now radio turns on but no sound in speakers, any ideas?
jumping the car backwards has likely blown fuses or burnt out components of the system, you need the dealer on this.
Jun 07, 2012 | Cars & Trucks
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
My radio stopped working
Could be speaker fuse or fuses esp if played loud with bass turned up worst case is power transistors blown then you may as well scrap it considering cost of repair vs second hand radio. Look at wires coming out of back of radio to speakers for inline fuse holders push and twist to open.There could be a fuse in rear panel of radio. Sorry I can't tell you how to remove the radio
Apr 14, 2012 | Cars & Trucks
No sound comes out of the speakers when raido is on
set it to radio or put in a cd and put it on cd mode and try playing if there is no sound then check radio fuse in the fuse box to see if th eamp fuse is blown.
Apr 11, 2010 | 2000 GMC Yukon Denali
Power, but no sound
take an ohm meter and remove wires from speaker...put meter in the ohms position...you will put a lead on each of the terminals of the speaker...you should have a reading of 2, 4, 8 ohms....you may also try to use the continuity test, same, but there will be a beep ....this basically ensures that the coil running through the speaker is still good, as one piece, otherwise it will get no good reading and this is usually from blowing the speaker or sudden high bass sounds....
Aug 09, 2009 | Sony SA-WM500 Subwoofer
Radio
Check the connections on all the pins, If it is a plug and play adaptor, check your fuses, but most likely the speaker connections are slightly loose, which is causing the lack of sound. I find when removing stereos if the wires are shorter they disconnect, but stay in the housing.
Oct 21, 2008 | 1998 Mitsubishi Montero
Garbled sound
Your Codec is damaged. Reload your drivers for your sound card. First uninstall the old ones. Moving your non working speakers and they play fine says they are good. I have a problem that you have new speakers and the problem went away. Drivers do not care what speakers are on the other end. It only produces output. Now that your second pair is working correctly, put back the Harmons and see if the problem comes back
Mike
Apr 23, 2008 | Harman Kardon SoundSticks II Computer...
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
60 people viewed this question
 Grubhead
Grubhead
