Question about Whirlpool GSW9800PW Washer
I need a washing machine that I can set for cold tap water
I'm shopping for a washing machine that I can set on a true cold tap water setting to prevent shrinking 100% cotton clothing.
    President:
  • Whirlpool Master
  • 1,922 Answers
Just shut off the hot water at the faucet and you will get 100% COLD water I guarantee this on any machine you buy
Posted on Nov 19, 2009
Cold Fill Washing Machine Does Not Get Hot
Do y7ou have 2 hoses at the back of the machine one for cold water and one connected to the hot water tap of the house. If not then you have a cold water in only. If you have 2 hoses have you connected the hoses into the machine correctly Have you checked to see if your machine has a heating element under the bowl for heating the water. As an appliance shop to verify if you have by the model number of the machine. otherwise you have a cold washing machine and unless you can plumb hot water to it that is all you will have.
May 29, 2013 | Siemens Washing Machines
Installing a Miele WS5425 cold water fill only?
if you only want cold water for washing, just select cold wash in the program settings and turn off the hot water tap
so the settings you will be looking at are --like --
tub fill ---low water medium water or high water
water temp cold or hot
rinse hot or cold , wash setting --heavy , delicates , whites , woollens etc
may not be exactly worded like that but you get the idea
when ever you see wash temp or water temp , select-- cold
Jul 08, 2017 | Dishwashers
I need to wash the colors in cold water ONLY but when I set the washer on cold, it still washes clothes with warm/hot water for part of the cycle, causing the colors to bleed. How do I need to set it up...
G'day, simple solutions is to swop your hoses at the back around, you can do this at the taps... If you only have one hose going into machine, you need to make sure the hose is on the cold water. Some new machines heat water internally, hence they don't need hot water going in at all. Sounds like you are putting hot water only into your machine. If you only have a hot water tap in your laundry for washing machine, this cold be a problem as the machines don't cool down the water. If this is the case you might have to look at other plumbing solutions... Hope this helps, let us know how u get on
Aug 08, 2011 | Washing Machines
Simpson esprit 450 washing machine timer not working. It statrs at a certain point (rinse) but doen't work when I set it for wash. It does rinse, deep rinse and spin but doesn't wash at all.
Hi just read your posting.Now just a couple of questions.What water temp have you set the machine for,Is it cold,cold or another setting.Have you got the cold hose going from the cold tap to the cold water valve on the machine with is marked with a C and the same for the hot which is marked H.Please reply with answers to all the questions and I am sure I can help you with this fault.Looking forward to your reply.
May 24, 2011 | Washing Machines
When washing machine goes to rinse cycle, water barely comes in
I am going to guess you run a warm wash, and cold rinse. This sounds like the screen on the cold water inlet is clogged. Shut the water off and remove the hose at the back of the machine. Look in the water inlet and see if the screen is clogged. If so, carefully scrape it as clean as you can. Use a straw and blow into it to help clear it out. Replace the hose and try it. It does not need to be perfectly clean, but at least half way opened will suffice.
Jan 01, 2010 | Kenmore Washing Machines
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
My Admiral Washing machine only runs the hot water (not cold)
if you want to use cold water, switch your hoses from hot to cold and cold to hot. You will get cold water now
Dec 06, 2008 | Kenmore Elite 45986 Front Load Washer
the water temp switch is bad call aplience parts store in the area
Nov 25, 2008 | Admiral AW22 Top Load Washer
Temperature control
hi thanks for the question . make sure the cold water tap is on . if on. no cold water. replace the water valve . thanks the appliance doc
Sep 28, 2008 | Washing Machines
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
Whirlpool GSW9800PW Washer Logo
81 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
