Question about HP OfficeJet 6110 All-In-One InkJet Printer
No dial tone when I try to fax a doc after years of normal ops
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
leroyal
  • 2120 Answers
SOURCE: No dial tone on fax machine
Yes, all fax machines are analog.
Posted on Mar 03, 2009
crapiemael
  • 241 Answers
SOURCE: HP OfficeJet 4215 can not send fax
Check for dial tone at the fax machine
Plug in a telephone on the cable from the wall.
Do you get a dial tone?
Yes,
Something is wrong with the fax machine.
No,
Call the phone company or a telephone repairman.
Posted on May 27, 2009
  • 40 Answers
SOURCE: C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Posted on Jul 27, 2009
  • 3 Answers
SOURCE: Fax machine not sending documents
A) Run the fax test on the printer itself to see if it's connected properly and has an active phone line.. HP All-in-one printers still make a dial tone sound even if they aren't connected to a phone line. To run the test 1)..Press the SETUP button. Press the down arrow button until "Tools" is highlighted then pres OK. 2) Press down arrow key again and select "Run Fax test" The printer will then print out the results. It will tell you if anything fails. If it does, the correct the problem it mentions. IF everything passes, then the problem is likely your cable phone line which is a "Digital" and Fax machines still use an analog signal. Here is what you can try to overcome the deficiencies in a cable phone system. 1) Set your fax speed to Medium 2) Turn your ECM (Error correction mode) OFF
To set your fax speed, Press the SETUP button again.. Press your down arrow again until you find "Advanced Fax Settings" and the press OK.. arrow down until you find "Fax Speed" and hit OK. Then choose Medium (14,400) and press OK This will take you to your previous menu (Advanced Fax setings).. Find "ECM Choose OK again.. Then choose OFF and press OK. Press the X button on your printer's control panel and then Retry your fax.. Hope this helps
Posted on Jul 21, 2010
How fax says File full and will not fax any docs. How do we fix?
First I would plug a regular phone into the phone line to make sure it has a dial tone. Assuming that works send a fax to your cell phone and see if the fax machine dials out and makes your cell ring. Assuming that works check the fax for an error code as to why it is not faxing or failing.
Feb 11, 2010 | Panasonic UF-4000 Printer
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
No dial tone
plug out the fax... plug in a phone... if still no dialtone... replace phone cable... still no dial tone... call the phone company...
plug out the fax... plug in phone... dial tone heard... bad fax... try to reset fax machine... per instructions... still no dial tone... call repair guy...
Dec 18, 2009 | Office Equipment & Supplies
Dead key
If you are handy....
Open doc feeder'
Pry open the op panel with a screwdriver
unplug and unwind the white harness
Remove the 17 brass screws remove op panel
Unsolder and remove a key switch you don't use such as CONTRAST
Replace 8 switch with the one you removed.
Sep 17, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
OT OFF SENT REPORT & ON DIAL TONE
Try sending a test sheet using "hook" to a known good fax if it goes the fax is fine (it wont leave the doc feed till its coming out on the rx. fax.) If this works then maybe the speaker is bad or disconnected. As for the report you need to chance the transmission report to off or error.
-Carl, please let me know if this helps.
Mar 21, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
No dial tone
Very strange that there a no other symtoms.
Are you sure you are plugged into the LINE port of the fax machine?
Oct 18, 2008 | Brother IntelliFAX-2440c Plain Paper...
No dial tone
Problem solved - new cable bought which seems to have sorted the problem.
Sep 26, 2008 | Brother FAX 930 All-In-One Thermal Printer
No dial tone
Sounds like the phone line may be dead, try to put another phone on that line and make sure the phone line is active.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Put in number press the green button to send the fax and it comes up with Memory Set Doc flashing but wont send the fax.
try sending manually
to do so
load a document---->press hook----->dial the number----->when you hear a fax tone press start.
Aug 05, 2008 | Canon L120 Fax Laser Printer
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
HP OfficeJet 6110 All-In-One InkJet Printer Logo
52 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
