Question about Weber Q Grill
Coals dieing out
I have a 22" standard grill. the coals on one side always seem to die out when cooking indirect, or even when i cook direct one side seems to stay lit better
  • 10,865 Answers
It sounds like you have a partial block to the fresh air supply on the side that is dying out on you. The cause is generally built up grease residue, or coals blocking the air flow. Look carefully, readjust things and you should be all set. Regards, Joe
Posted on Nov 18, 2009
Meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 | Grilling
How do I cook ribeye steak
on the grill! get yourself nice dryrub at your local food store and throw it the grill. i dont let my temp get higher then 300 i cook them low and slow!
Dec 08, 2014 | Grilling
The users manual arrived with the product but there are no user instructions and aswell as direct grilling I want to use the grill to cook joints etc. What setting do you use for indirect grilling and Is...
Direct Grilling is putting the items you're grilling directly over the burner(s) . Indirect Grilling is preheating the grill, turning off one or two burners and place the food over the burners that are OFF. In direct grilling requires cooking with the lid closed.
For more info on using a gas grill, as well as recipes got to the following link.
http://www.barbecuen.com/begin-gs.htm#axzz1SkGNJ9p8
Happy Grilling!!
Jul 21, 2011 | Ducane Affinity 3100
Is meat placed in main grill or in attached box
The "offset" box is your firebox. This is where you will put your charcoal. The meat goes in the larger chamber on the grill. This type of cooking is known as indirect cooking where the heat source is not directly under the meat. A grill cooks direct with the heat source coming from charcoal or gas burners located directly under the cook grills. Smoker can really deliver some great tasting food. Be patient and learn the ins and outs of cooking with a smoker. The most important thing is to cook low and slow. try to keep your temps in the cook chamber around 225. I hope this helps.
Jun 29, 2010 | Char-Broil Sierra Offset Smoker
How do I use this grill? Charcoal in the larger cavity and wood in the firebox???
I assume you have the model with the side firebox? If so, when smoking you have your charcoal and wood in the firebox and the meat to be cooked in the large cook chamber. This is indirect heat cooking. Your cooker is dual purpose. You can load the large chamber grates with charcoal and cook as would with a charcoal or gas grill (direct heat cooking), or you can cook low and slow using the smoker portion. The heat comes in from the firebox and into the cook area. Ideally the temp in the cook chamber should be around 225 while smoking meats in this manner.
Google "smoker forums" and you will find a group of guys will to help you learn to cook with a smoker and share cooking secrets.
I hope this helps.
Jun 21, 2010 | Char-Griller Wrangler Charcoal
Cooking a whole chicken / lamb roast
Good Evening, I love cooking with Charcoal/Wood. The bottom vents will adjust the temp, closed the coals burn slower and cooler. The top vents also control the temp, however more importantly the flavor by keeping the smoke in or out. With a roast you want low heat so I would close the bottom vents 1/2 way or so and since i like a smokey flavor of Hickory would keep the top vents closed. The key to a good Barbeque none the less is slow cooking. It also takes fine tuning, wind, breezes all effect how fast/hot the coals burn. Don't be afraid to add more coals as needed as well. Good Luck and have a great cookout. Thanks for using FixYa. Jeff
Apr 20, 2010 | Weber One-Touch Gold 18.5 Grill
Cooking info
You can print a new manual off of www.chargriller.com. But, the basics are:
1) Take cooking grates off of grill
2) Put enough charcoal on the grill to cover the desired cooking area two coal layers high
3) Pile up desired amount of charcoal (laid out in step 2)
4) Spray lighter fluid all over charcoal pile
5) Light the pile
6) Let the pile burn until the flames die out and most of the coal has turned white
7) Spread the coals back out (use tongs they will be hot). Put any coals that are still black on top of the white ones.
8) Put your cooking grates back on the grill and let the last black coals turn white and the grates heat up.
9) Now cook!
Apr 14, 2010 | Char-Griller Super Pro
Coal starts dying out the moment I put the Grill
even with all the vents open the air is restricted with the top on. This is what makes the kettle such a remarkable cooking machine. If you wish to grill then leave the lid off and cook directly over the coals, if you are grilling a thicker cut of meat such as a 1 1/2" thick porterhouse you might want to put the lid on for a while to more or less bake or broil the meat without blackening the surface of the meat and to achieve the desired internal doneness of the cut. you can also stack your briquettes/lump to one side and put the lid on so the exhaust is opposite to create a non direct cooking environment for cuts such as butts, ribs, briskets, whole chickens etc
Sep 12, 2009 | Weber One Touch Silver Charcoal Grill
My Kenmore grill that was purchased maybe 6 weeks ago, burns all of our food in min. even on lowest setting. Sometimes the food is burnt outside but not quite dont inside.
you have a multi burner grill start out grilling direct then move to indirect to finish food turn off burners that are directly under food
Aug 03, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
I have purchased a used upright New Braunfels Smoker and need an instruction manual on how to use it, ie. how much charcoal, cooking times, etc.
fill it almost half way spread it evenly and make sure the coal is fully fired before you but any meat in. If charcoal still burning not fully fire and red do not put any meat in the grill. Cooking will depend on what you cooked and quantity of meat. The more the meat the longer it will take. My suggestion is to keep your eyes on what your cooking and if need to pull the meat out and test it if needs to. By testing the meat here and there paying attention with hands on will give you and idea how your grill works. everyone cook or smoke differently, some like it juicy and other like it juicy/dry or fully cooked. Buying a grill is like having a new girlfriend, you have to get the feel to know that person. Smoking will take a bit longer than standard grilling. Hope that help some..enjoy!
Jul 10, 2009 | New Braunfels Cattleman Smoker 99204805
Weber Q Grill Logo
90 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
