Question about X2Gen MG19MY 19" LCD Monitor
How do I open it to look inside? - X2Gen MG19MY 19" LCD Monitor
  • 4 more comments
  • f_riding Nov 18, 2009
    I know i'm going to wear rubber gloves. I think its a capacitator problem.
  • f_riding Nov 19, 2009
    Yes I have a nice pair of safety goggles to go with my rubber gloves that are really quite fetching...
    I would like to point out that the monitor has NOT been in use for over six months. Therefore the risk of electric shock from the charges should be at a minimum.
    Also I will only be changing only the blown or leaking (spent) capacitors and will do so with extreme care to prevent any of the unwanted explosions you refer to.
    I have researched this procedure thoroughly and carried out my own risk assessment, but would NOT recommend anybody else trying to open up their monitors themselves due to risk of serious injury, maiming or indeed death.
    To clarify, I do this at my own peril and should anything terrible happen then I will have nothing to blame except for my own stupidity and stubbornness in not wanting to fork out another 200 bucks on a new LCD monitor.
    Thanks for your help and your time.
  • f_riding Nov 20, 2009
    ...anyway job done. It was easy. I Changed 3 small capacitors which cost 50 pence (around 30 cents) each and the monitor is working like it?s brand new. So, in total, it cost me in total £1.50 to fix as opposed say £100 (conservative estimate) for a new monitor. I feel that I have saved not only money but also the environment as it would have only ended up in the, ever expanding, monitor graveyard.
    My question is: why don?t LCD monitors come with serviceable parts? I mean £100 - £200 for a new one isn?t chicken feed (especially in these times), also it seems to me that there is plethora of broken monitors lying around which could easily be refurbished, yet aren?t. Is it merely a safety issue? Or could it be down to the manufactures wanting more money from more purchases. I know what my money is on...
    Anyway don?t try this at home kids unless you are an expert in changing capacitors which I certainly am NOT.
    Fran
  • Project NOMAD
    Project NOMAD May 11, 2010
    . I can attest to over a year for an HV large cap holding enough charge to cause damage to metal objects. Many individuals do these types of repair with no real harm but there are those that as you say read info from the net and think its OK to DIY. Best advice is to stay away unless you are QUALIFIED to work inside monitors or other equipment that may use HV. I would recommend Joecool's extensive and careful advice without hesitation for anyone contemplating such work unless that person is willing to take on ALL risks.
  • joecoolvette
    joecoolvette May 11, 2010
    I appreciate your being safety conscious, (Really!) My other concern here is not only you, but possibly people around the world that might view this problem. When someone 'Googles' information off of the internet, this problem/solution could come up in one of the search hits. Your problem, and any subsequent solutions, will be here for years. Another person comes along, uses the information provided, opens the monitor, and could receive a Bad Shock, or Fatal one, if no safety advice is given. Also be aware that capacitors are designed to hold a charge, then suddenly release it all at once. They can hold a charge for Weeks, sometimes MONTHS, after power is removed from the electronics device! Wear a face shield also. Really! Not playing! When Electrolytic Capacitors are failing they develop Hydrogen Gas. The Electrolytic Paste inside the 'Cap' does this. If the Caps are not PROPERLY discharged before working on the unit, there is not only a chance of Shock, but also a chance one or more capacitors could Explode! (Using a metal screwdriver to discharge Caps, can get you melted pieces of steel in your face! This is Not the proper way to discharge Caps) Thank you, and BE SAFE!
  • joecoolvette
    You don't. There are high voltages used inside, hence the No User Serviceable Parts warning. It's a safety issue.
  • 148 Answers
First, lay the tv/monitor on its screen on something level and soft as not to damage the screen. Remove any visible screws that seem to attach the base to the unit. Some models you have to look under the base for pins orso to push together to slide the base from the stand, only then you could reach the 1 screw holding the monitor to the stand....Once stand removed, remove any screws you see holding the monitor casing together, usually only a few screws since they are mostly held together by plastic "clips"...Once screws are removed, then gently insert a flat(screwdriver orso) inbetween the case?housing, repeat this all the way around the case/housing till completely loose....You will prob have a few wires or maybe a ground wire that you would have to remove before completely being able to seperate both sides(front case, back case)..Sometimes you might have to unscrew and remove the skinny washer/nut around the cable input orso..
Posted on Feb 01, 2010
Door only opens from the inside
Take out the lock and you will see the rod which slides up and down to connect to make the lock open it may be worn out have it replaced or tie a wire such as a copper wire from unused electrical wires to tighten the gap which may be lose which as a result does not catch properly to open the lock
Sep 16, 2015 | Cars & Trucks
Open door manually
can it open from the outside? There is a child safety lock inside the door when open it could have been put on child proof not allowing a young child to open the door from the inside but it will still open from outside. if this is not the problem then your rod has disconnected from the latch mechanism inside the door, you may need a slim jim tool or try to remove door panel from inside, this will be difficult when door is shut but maybe possible depending on the door panel itself, they may have some screws but most just snap in.
Dec 10, 2013 | Cars & Trucks
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
I cant open my door from the inside of my 01 isuzu rodeo. Opens fine from outside but not the inside.
You need to remove the door trim to expose the inside mechanism that opens the door from the inside, look for a broken cable or a missing link to the inside handle, your problem will be there.
Mar 19, 2013 | 2001 Isuzu Rodeo
1996 Chevy Silverado inside and outside handles to open broke. How do i open it
Only way is to get a coat hanger and make a small hook on one end and try to slide it between the window and door panel and try to hook the door latch from inside the door.
Jan 26, 2013 | 1996 Chevrolet C/K 2500
1986 nissan 300zx passenger door wont open from inside ,can from outside
Remove the inside door handle cover , Take out the piece that has yhe rods attached to it . There is 2 black plastic pieces that one opens the door and the other one locks the door. One is broken . The one that opens the door from inside, Reolace the piece and put the rods back on. put cover on . Done.
May 07, 2012 | 1986 Nissan 300ZX
Drivers door wont open
If it were me , I'd remove the inside door panel and take it from there. It may be that you can pry open the lock mechanism with a screw driver or a similar tool, allowing you to open the door - which obviously you must do. Even that, though, will not solve the cause of your problem. You may wind up at the dealer.
Aug 19, 2017 | 1986 Ford Tempo
Drivers side door will not open from the inside but works from the outside.
Open the inside door panel.
There is a big wire that connecting door open lever to the door lock,
The wire could be not in the proper posiiton, and its cause the door cannot open from inside.
Sep 06, 2009 | 1997 Mercury Cougar XR7
Driver side door won't open from the inside.
remove the inside door panel reach inside and, reattach the clip to the inside door lever rod
May 22, 2009 | HP Compaq Presario V5204nr Notebook
Doors will not open from inside
undo the child locks. These are located on the side of doors.
Nov 14, 2008 | 1999 Nissan Maxima
X2Gen MG19MY 19" LCD Monitor Logo
556 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
