Question about Nintendo Wii Console
How can I run my Wii through the DVD player? - Nintendo Wii Console
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
Sep 07, 2012 | GE 25GT240 25" TV
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
Can't hook the WII and the DVD player both up and the same time.
You can hook the Wii up with the standard RCA jacks and the DVD with the HDMI or vise verses. How many hook ups are on this TV. You can also run the Wii through the DVD using a aux channel on the DVD.
Dec 26, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Moving from Ireland to Canada with Wii and DVD Player
Is it a new TV? I am not familiar with the Ireland/Canada signals. But it could be a PAL/NTSC conversion issue.
Jan 01, 2010 | Nintendo Wii Console
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
I do not have the proper hook up on tv so can i run the wii through the dvd player
Whay do you want to run Wii through DVD player. Can't you hook it into one of th inputs on the TV.
Nov 22, 2009 | Dynex DX-L42-10A 42 in. LCD TV
How do I hook up my dvd player and WII system to my Dynex 42 inch LDC flat panel tv so they are both in color, what inputs do I use ?
Allot depends on your DVD player and WII. Since the TV is a color one unless the movie your watching on the DVD player is B/W it will play in color, same with the WII. If your DVD player supports HDMI then select one of the HDMI ports on the TV (there are 3) same for the WII depending on what outputs it supports select one of the corresponding inputs on your TV. The user manual shows several options for various components and should be of some assistance in your connections.
Nov 14, 2009 | Dynex DX-L42-10A 42 in. LCD TV
I cant figure out how to run it through my dvd player
You should not be able to, the Wii has a mini disc player and is not compatible with any DVD player. The DVD player should have two plugs on it, one to the wall input and one with yellow and red input jacks if you don't have a AV in-put out-put connection on your TV then you need a adapter for to TV for the DVD player.
May 19, 2009 | Nintendo Wii Console
Nintendo WII wont work on my AV
try getting a converter module.... can pick one up cheap at most electronic stores
May 07, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
346 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
