Question about Admiral AW22 Top Load Washer
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
    President:
  • Admiral Master
  • 1,922 Answers
You will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Posted on Nov 19, 2009
Just want to get in between the two tubs. Think I have a nail in there. Can't figure out how to get the top off. Can u help?
Front Loader?
That won't get you between the tubs. The inner and outer drum can only be accessed from the front. Big Job! I would get a powerful flashlight and shine it through the holes in the drum. Pull out the nail with a rare earth magnet taped to a stick and inserted under the drum.
Top Loader?
Undo the plastic nut on top of the agitator and lift it out. Use the same technique with flashlight and magnet.
More likely to be a coin.
May 01, 2016 | Washing Machines
Samsung top loader, inner and outer drum not cebtralising and making noise when spinning
check for unbalanced spring tensions and some dirt in the agitator motor. thanks.
Mar 02, 2016 | Samsung Washing Machines
How to remove a samsung 8kg top loader drum to pressure clean and remove black rubber like build up
No need to remove the drum. You can buy cleaning agents for the washing machine at the local supermarket. You have to actually run the machine in cleaner solution and you have to do this every 3 months at least.
Jan 16, 2014 | Samsung SW62ASP Top Load Washer
Samsung front loader washing machine
Sounds very much like the drum bearings have failed. It is not a DIY job I'm afraid. Up to date washing machines are now impossible to actually replace bearings and only way to repair is to replace inner and outer drum assembly. This is a 1/2 a day job at the least to a professional. Older machines.....you can replace the bearings but this still involves removing the outer drum ou from under the washing machine, and the a very normal bearing removal and replacement procedure. Make sure the bearings are knocked in very straight and not on the skew. Good luck
Nov 24, 2013 | Washing Machines
How do I remove the top of whirlpool awoe 9140 front loader washing machine?
there are 2 or 3 screws behind the top cover,but this wont get you to where the odor exists,its in between the inner and outer drum,you need to also remove the front cover including the door then remove the inner drum pulley and belt and then split the outer tub to clean out old detergent and fabric softener if you use this as this is where the smell is coming from
Jan 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
GE Front Loader rubber boot completely out of shape
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
Oct 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
Admiral AW22 Top Load Washer Logo
680 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
