It has gone out of tune. I now can get only 11 channels on the list, most of these are repeats ie BBC2 comes 3 times and ITV twice. Outside the big 5, I have channels 40,41,43. How do I retune?
  • 834 Answers
Someones been playing you need to re run setup in the Canle mode and you dhould br ok
Posted on Nov 18, 2009
How do I change the Chanel numbers on my technomate
sorry but you can not renumber channels .
Oct 01, 2016 | Televison & Video
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
Can get bbc picture but not the other channels
BBC1 and BBC2 are among the strongest signals you could simply have a low signal reception, try a channel dump and re scan for all digital signals, try re tuning on a different aerial if that's possible. If all this proves fruitless the fault will most likely be on the Main AV Panel where the tuner an IF stages are found. Post your Brand and Model Number for more specific help suggestions
Dec 30, 2015 | Televison & Video
How do I re-set the tv channels on my Blaupunkt TV?
Reset Or Re-tune? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 18, 2015 | Televison & Video
How can I get channels in sequence eg bbc1bbc2
Depending on your model, select channel 1 and tune for BBC1 and then 'store'. do the same for channel 2, tune for BBC2 and store again. Just repeat with each channel in turn
Jul 01, 2014 | Televison & Video
I am trying to retune today 4th April I select menu, then set up, installation, first time installation,
You have a life right your will will or should find the answers you need so just take your time and figure it out if you truely want to you will
Apr 04, 2012 | Televison & Video
Toshiba 19DV500 b will only pick up BBC1, BBC2, ITV, C4, C5 no freeview channels. there is no reset or reinstallation options
Hi, sounds like you are in Analouge mode and not in DTV mode so you can't access the DTV menu to tune in the tv.
Press the 'SOURCE' button and move to DTV using the arrow keys, then press ok and if channels aren't already tuned you will now be able to tune them by accessing the DTV menu by pressing the 'MENU' key on the remote control.
If you don't have the manual you can download it or view it by clicking ----> HERE
Hope this helps.
Feb 09, 2011 | Toshiba Televison & Video
Cant remember how to tune it in
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your Sanyo from the list which follows:
    154, 159
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
Jul 30, 2009 | Televison & Video
Tuning a Toshiba CT 9689
I just tried finding a manual for the toshiba and didn't find much. In the setup menu there should be an auto setup for tuning in channels. Cable or off-air. Let the system do an auto set-up to find channels available. I'll keep looking for a manual. Let me know how you do.
Sep 22, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
