Question about SE Electronics Z3300a Professional Microphone
The wiring has snapped from the mic to the xlr socket on the microphone is there somewhere i can get a diagram to fix it? the mic is a se electronic z3300a
    President:
  • 1,138 Answers
It uses a standard balanced XLR wiring which is 1= ground/shield, 2= (+ve) hot and 3 is (-ve) cold. Do not bridge pins 1 and 3 as this mike uses phantom power. Please let me know if this helps.
Posted on Nov 20, 2009
Just got my sE X1 bundle pack, plugged it in, set the proper settings in preferences and no signal to my Garageband?mac
To connect this mic to your iMac, you will require the following:
  • XLR mic cable
  • Recording interface or Mixer with phantom power
Jan 17, 2014 | SE Electronics SE X1 Microphone
Does the Behringer xm8500 work on it's own, or do I have to hook it up to something? My daughter wants a microphone she can sing into.
All microphones have to be hooked to an amplifier to work. The socket at the bottom with the 3 pins in it is called an XLR jack. You need to plug an XLR cord into that and then plug it into an amp that has an XLR or 1/4 inch microphone input (using an adapter).
If she just wants it for looks, then no, you don't need to plug it in.
Jul 03, 2011 | Behringer XM8500 Professional Microphone
PH62080 mic has 1/4 jack. Can it be converted to XLR connection?
Yes it can, with a little help from amazon.com
http://www.amazon.co.uk/6m-Female-XLR-jack-cable/dp/B001GE4CV2/ref=sr_1_1?ie=UTF8&qid=1299774085&sr=8-1
They have a range of converters that will help you
Hope this is what you where looking for
Mar 10, 2011 | Philips PH62080 Uni-Directional Microphone...
My se x1 condenser mic has starting to cut out, usually just for a second and it seems to be when louder noise goes through it (though this is not too loud as its not clipping on my mixer or software)
Clipping can occur at any point in the chain of electronics and may NOT show on your mixer.
Also cheeck your phantom power voltage sent to the mic. Some mixers send much lower than the +48 volts and clipping within the mic electronics can happen with these. Check the voltage between either pin 2 or 3 and pin 1 of the XLR. Note that the pin numbering on XLR's is funny... search google for diagram.
Jul 19, 2010 | SE Electronics Professional Microphone
Is a dual XLR adapter available for the MV-P612U JVC stereo mic.
The MV-P162U is a stereo mic designed to plug into a JVC professional camcorder. dates from the 1990's and was very expensive.If the 6 pin plug has not been cut off, and you can get a socket to fit, then going clockwise around pins (or wiring side of socket) from the locator.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
suggest a small breakout box. tested it with a 9v battery - the drain is 14ma. could run from 12v via a 285 ohm (approx) resistor with a 47uf cap across the mic supply.
May 05, 2010 | JVC MV-P612U Professional Microphone
AKG Model C451 EB Microphone.
I drilled a tiny hole (.038") through the outer shell and the cartdrige where the body of the XLR connector is mounted and screwed a tiny screw into it from a pair of old glasses.
Sep 29, 2008 | AKG (WMS40DIV444US54) Microphone
SE2200A "wind" noises during recording
Its very descriptive and is quite a common problem with less expensive condenser mics. It's due to dirt or contamination on the capsule insulator or front end circuitry of the electronics. SE should be able to fix it for not much money.
Aug 26, 2008 | SE Electronics SE2200A Professional...
Bogan DDU250 Decktop mic
the tip is is soldered to 1 and the sleeve/ring is soldered to 2 on a xlr. thanks nate. i have pictures i can email you if you need more.
Aug 21, 2008 | Bogen Communication BOGEN DDU250 DYNAMIC...
Does the SE Mini use a standard cable or is there a special cable needed for use in an amp or computer?
you'll need an xlr (male) to xlr (female) to use the microphone with 48v phantom power (from a preamp). phantom power dosnt work with an xlr to jack, only both xlr.
Apr 22, 2008 | SE Electronics SE MINI Microphone
SE Electronics Z3300a Professional Microphone Logo
264 people viewed this question
Top SE Electronics Audio Players & Recorders Experts
Michial Gueffroy
Tom Chichester
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
