Question about Toshiba Satellite A100-S8111TD Notebook
The on button on my Toshiba laptop is beginning to not work (I'm lucky to be able to get it to turn on.) Can a repair tech replace that button so I don't have to worry that I won't be able to start my computer? Diana
  • 846 Answers
If your laptop has soft touch buttons somewhere else on the computer or the screen they sometimes turn on the computer as well. If it's actually the button that's broken,which any repair shop will replace for you , I work for Computer Repair NYC andwe do this repair frequently.
Posted on Dec 21, 2009
    Problem Solver:
  • 15 Answers
Yes i hope tech can replace the button
Posted on Nov 18, 2009
  • 748 Answers
If your laptop is out of warranty, you should look for a repair service that will charge you only for the replacement of the button (which involves quite a lot of work, to be honest, so it won't be extremely cheap), and not a repair shop that will tell you that they don't care which part is actually broken, and just replace the whole motherboard, which will cost you half the price of the laptop.
If the computer is still under warranty, then you are good, because it's not your problem if the service will replace the button or the whole board inside :)
Good luck :)
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
Toshiba laptop a210-15k wont turn on .power lights and battery lights on .when i pres the button of power it begins to stars and I hear the noise of the fan moving for 10 sek and then the fan slows down...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 10, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Last night my Toshiba's screen turned white with a few red and yellow stripped lines. Than the white filled in with black over night. Now the screen is blank, the power button won't turn it off only on....
HI There,
I'm a pro laptop repair/rebuild tech. If you own an external regular computer monitor or even a friend who does, connect the laptop to the external monitor and power it on. Your Toshiba will have an F key with a little icon figure of a monitor on it. Hold down the fn key and press that F key to transfer the laptop display signal to the external monitor.
If the external monitor shows your normal laptop screen as it would usually display, you have a bad laptop LCD and some other (as yet) undetermined problem. If the external monitor is black just like the laptop, then yout video/graphics card has failed and since it's closely associated with power up issues at the beginning of the startup cycle, is interfering with the laptop's ability to run the operating system because it never gets that far.
From what you've described, you're going to have a choice of sending the laptop to a motherboard repair service (if you go to eBay and type "Motherboard Repair Laptop" in the search window you'll see many choices) for a price between $100 and $200 or need to start shopping for new laptop.
Remember, "don't shoot the messenger"!
Good Luck
Aug 05, 2010 | Toshiba PSAFGU-058002 Notebook
The hinges on my Toshiba Satellite A85 Laptop are broken....Can they be repaired?
The hinges can't be repaired, but can be replaced. It's feasible to do it yourself if you're tech savy. Just look online for guides that show you how to replace the hinge on any toshiba laptop and you should get an idea how to do the replacement step by step for this specific model. I work for Computer Repair NYC and i have to fix this problem a lot, you can get the hinge on ebay.
Oct 02, 2009 | Toshiba Satellite A85-S107 Notebook
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Laptop seems in sleep mode or shorted
go on bious save first hdd second save room then exit it can solve yor problem.
Jul 13, 2009 | Toshiba Satellite M35X-S149 Notebook
Display has lines on it
Well I hate to say it but there is a problem with either the motherboard/video card or the screen itself. Neither of which you can repair yourself.
If it's still under warranty id contact Toshiba (Google there website)
and find out how to send it to them and ask anything else you wanna know and let them repair.
If its not under warranty you can either buy a new laptop, or find the parts if your lucky on Ebay, and repair it yourself but you don't know if its the motherboard/video card or Screen (Hard to find out which without a service tech looking at it). Plus Laptops aren't as easy to work on even with instructions.
Jan 09, 2009 | Toshiba Satellite M40-S417TD Notebook
Toshiba 2435 remove top to check buttons
Here is the site I use for Toshiba Laptop Repair. Hope It helps and Have a good day.
Dec 24, 2008 | Toshiba Satellite 2435-S255 Notebook
Laptop won't start.
Those are items I would have done myself to test it. It sounds like some item is bad on MOBO (motherboard) it will have to be replaced in any case. I would order a new battery and a replacement MOBO for that unit. If your under a warranty Toshiba would have you send back the laptop to them so they can repair it. Or have local authorized service center send a tech with replacement parts to fix it onsite.
Aug 06, 2008 | Toshiba Satellite P105-S6104 Notebook
Problem with Motherboard
I had the same problem. I took it to my nearest toshiba repair center, turned out the hard disk was defective/corrupt, the tech repair guy replaced it and it worked inmediately. Good Luck.
Nov 07, 2007 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite A100-S8111TD Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
