Question about Brother MFC 3220C All-In-One InkJet Printer
Cannot figure out how to set ring cadence(tone)
I have a customer who has a brothers mfc 3220c and a distinctive ring piggybacked off of his regular phone #. we cannot figure out how to get him setup w/ the correct ring cadence option so his fax will answer faxxes only not all of his calls, what should i do??
  • Brother Master
  • 1,113 Answers
Turn on distinctive ring option as out lined in user manual.
Download manual from brother's web
Posted on Jan 10, 2008
I cannot set my MFC 8460n to receive faxes - it says it is in DR mode
The machine is set to Distinctive Ring mode.
Turning off Distinctive Ring
Press Menu, 2, 0, 2
Press a or b to select Off. Press OK
Press Stop/Exit.
Mar 05, 2011 | Brother MFC-8460N All-In-One Printer
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
I have a brother mfc 6800 and do I need a telephone line on it?
You will need a phone line connected to the MFC 6800. If you have a separate line for your fax number, make sure you connect this line to your MFC 6800. If you have a different ring, but on the same line as your phone number, you'll need to set up your MFC to utilize the distinctive ring (see the manual for setting this up).
Jan 26, 2010 | Computers & Internet
What type of usb cord is needed for this printer
Hello there:
here is the information that you requested ok
I hope that this is very helpful for you
Best regards Michael
Cables for the Brother MFC-3220C 5-in-1 Color Multi-Function Center: corner1.gif Part# Price Status Qty. Belkin PRO USB 6' Cable
USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft F3U133-06 $8.99 In Stock Belkin 10' USB Cable
A/B Type, Hi-Speed USB 2.0, 10 ft F3U133-10 $14.99 In Stock Top
Nov 24, 2009 | Brother MFC 3220C All-In-One InkJet...
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
Setting up distinctive ring to receive fax with only 1 phoneline
Follow the step in this Brother document:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000300/000005/faq000305_004.html?reg=us&c=ca&lang=en&prod=mfc7820n_all
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 03, 2009 | Brother MFC-7820N All-In-One Laser Printer
M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Mar 04, 2009 | NorStar Meridian M7310 Phone
Distinctive Ring not working, all calls passed to computer
uninstall all the software reset the printer to default settings and start over... kids were prbly messing around with the buttons and something got lost in translation
May 28, 2008 | Brother MFC-8440 All-In-One Laser Printer
Print head for brother mfc-3220c
how do you remove the ink cartridge from mfc-3220c when the lever is stucki
May 18, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC 3220C All-In-One InkJet Printer Logo
108 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
