Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Bizhub c 250
When I make some prints the colors standing next to the black text, i replaced the transferbelt and the drums
  • 44 Answers
Run stabilizer and gradation. Also check color registration.
Posted on Nov 29, 2009
I have a KM bizhub c 451 black imaging unit that prints faintly. I have replaced the following parts, PC drum, PC charger and starter( developer), yet it is not printing solid black.
replace the black image unit as a whole you do not replace the units as individual parts. Where did you get the drum from? or the PC charger as they come as one and you don't replace the developer as it is located inside the unit!!!!!!
Mar 22, 2017 | Konica Minolta Bizhub C451 Copier Print...
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
KONICA MINOLTA BIZHUB C253 DISCOLORATION
please attach pictures ....i have to see for better understundaning and solving your problem.
Aug 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Where is the Black Polygon Mirror Motor in the bizhub c203
there are four polygon motors in side the print head which is located below each drums, the polygon motor is what spreads LASER beam across the length of the drum with the image. To replace you replace all four yellow, magenta, cyan and black, black in particular because that is the reference color for the color print heads
Jun 25, 2014 | Konica Minolta Bizhub c203 Copier
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
C252 streaks
Check your consumables. Press utility then check consumables. If anything is at the end of life, it needs replaced. It sounds like your drums are not cleaning properly and need to be changed. If they are fairly new, then I would suspect the transfer belt. If you know hoe to get into service mode you can go into test mode. Then run your halftones on each color. If it moves around, its your drums. If it stays in one spot, its your transfer belt. Also you could check your drum units. If they have streaks going across the green drum, like its dirty, then its coming from the drums.
Apr 17, 2014 | Konica Minolta bizhub C450P Laser Printer
How to replace drum
Enter service mode and clear counter for drum, then power off the machine remove drum cart. then remove drum and replace with new one recommended that developer also be replace at the same time clear that counter first along with drum counter. once drum and developer replaced run F8 in service mode before making any copies or prints or will have to do it all over again.
Jan 12, 2014 | Minolta bizhub 250 Black and White Copier
KM7450 Vertical Lines in Magenta
I would replace the Magenta drum unit & developer unit
Jan 13, 2010 | Konica Minolta magicolor 7450 Magenta...
Konica bizhub 250
on the left hand side of the platen glass there is a **** glass just clean that with alcohol or wet rag.
HH
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
204 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
