Question about Goodman GMS90703BXA Heater
When I turn my heat on the red light comes on for 5 to 10 seconds and then blinks 3 times and then 1 time. but the heat will not come on. please help
  • 1,420 Answers
Lets look at the 3 blinks, it usualy means that the pressure switch is not allowing the gas valve to energize. Look at the vent termination for a possible blockage or something effecting either the exhaust or air intake. Next we will need to check the air filter and clean or replace it. Now lets open up the furnace and inspect all hoses going from the inducer fan to a drain or pump. All lines and hoses should be free of water and debris. Also check the small hose(s) going up to the pressure switch (a small round chrome disk with an electrical connection on it). They should be free of moisture. If everything I mentioned looked good, check the vent pipe from the furnace going to the outside for any low spots that may have water in it blocking the exhaust.
Posted on Nov 18, 2009
LG 47LN5750 TV has no back light issue-
replace screen it's faulty period ensure it comes with T-con
Oct 03, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Replaced bulb in kdf-50e2000- when powered on green light flash 3 times & fan engages, 2 seconds later fan quits and i get a 3 red light blinks
impossible to actually see if lever is Fully engaged---with door off try to engage with a match stick or something not metal--see if set comes on that way.
Apr 20, 2012 | Televison & Video
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Furnace will not respond to thermostat call for heat. Thermostat has been replaced with no effect. Have been informed it may thermocouple problem. Please advise. Thank you.
there's no thermocouple.there is many other safeties.hears what happens when you turn on;.1 draft inducer motor comes on. if all is ok with vent,then; 2 ignightor turns on .after a few seconds; 3 gas valve turns on if all limit switches and inducer switch are closed;.4 flame sensor checks for flame.after short delay fan comes on.if any safety switch is open theres no heat.look in little window and count red blinking light.theres a chart inside cover that will tell you whats wrong.some times theres water in tube going from draft inducer to diafram switch.the limits around fire box can be reset by pushing button in center.if theres no red light then low voltage transformer may be bad theres also a little fuse on board.if its blown you need to find out why.also any of these parts can go bad at any time.good luck
Dec 24, 2010 | Goodman GMS90703BXA Heater
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
5 blink red lights
Replace your Lamp # XL2100u Mats has them in stock 1-800-628-1118
Mar 24, 2010 | Sony Grand WEGA KF50WE620 Television
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony r60xbr1 tv turns on then shuts off and red stand by lite blinks 4 times
Moe,You have several Broken Conns via your Mother Board after doing about 500 in the Past 8 yrs,What you need to do is Get a Magnifying Glass and look at the Bottom of the Main Board and look for Ring Breaks around Conns *Note,Any thing on a HeatSink or Plug Conns,Will be Checked First,Use 60/40 Solder and a low heat soldering Pencil to Fix Good Luck ttech
Jul 24, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Goodman GMS90703BXA Heater Logo
147 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
