I cannot print. When I try to print, I get a box that comes up that says ''the ink absorber is full and needs to be replaced'' what i replace? can u describe please
SOURCE: what does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Posted on Nov 02, 2008
  • 183 Answers
SOURCE: waste ink absorber is full
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
  • Plug in power cable
  • While pressing Resume button press and hold Power button (do nor release the buttons)
  • Release Resume button (still hold Power button)
  • Press Resume button twice in a row (still hold Power button), after that release both Resume and Power button (then the printer standing bye)
  • Press Resume button 4 times then turn off the printer
In this stage your printer has operated as usual.
Regards,
Posted on Dec 02, 2008
pagebor
  • 2785 Answers
http://www.fixyourownprinter.com/forums/inkjet/50418#1
plz check the above website for more infomation
Posted on Mar 04, 2009
websnail
  • 419 Answers
SOURCE: When I try to print, I can't; it says "The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber."
This error means that the waste ink pads have filled up to the point where the printer believes the ink will overflow and leak or cause damage to the printer.
To give you a quick primer... Every time you run a cleaning routine or printer borderless photos the printer will dump a small amount of ink into a set of highly absorbent pads that live in the base of the printer.
These pads can only accept so much ink before they become full but experience has shown that you could reset the EEPROM waste counter if you locate the appropriate codes for your printer.
I'd recommend asking on nifty-stuff.com in the forums and see if someone can provide the information and code you need.
Hope that helps.
Posted on May 21, 2009
SOURCE: My printer, the Canon, Pixma Ip2000 stopped
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Posted on May 24, 2009
In printer canon ip 1800 is showing ink absorber is full cant use the printer
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer. Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 31, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is almost full problem is for cannon 1800
Hope you find this information helpful. The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example. Eight flashes indicates that the ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing.Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Mar 23, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
I cannot print. When I try to print, I get a box that comes up that says "the ink absorber is full and needs to be replaced"
try cleaning the ink absorber underneath the cartridges when they are resting in their bay area.Else try to replace it.If still not working,then the sensor for the ink absorber might be defective.
Aug 23, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon mx300 ink absorber full
my canon mx300 printer box flags that the ink absorber is full and the yellow alarm light comes on. i press o.k. and i can continue to print without a problem. can anyone suggest how i address the ink absorber - replaceable, cleanable, etc.?
thanks for your help
alan
May 13, 2010 | Canon PIXMA MX310 All-In-One Printer
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
Hope that helps.
May 20, 2009 | Canon Office Equipment & Supplies
Waste ink absorber almost full. What do I do?
Hi ...
Please vote if this helps ... Cheers :)
May 04, 2009 | Canon I960 InkJet Photo Printer
What does ink absorber full mean on Canon Pixma 1700?
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Ink absorber is full
Hi ...
Aug 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
k24674
jasbo
jasbo
