Question about Dymo LetraTag QX50 Thermal Label Printer
I just purchased new cartridges, but there's no print on the labe
I just purchased new cartridges, but there's no print. The labels are blank. What could be the problem
It was the batteries. I bought new ones and it works now. Good advice. Thanks.
Posted on Nov 19, 2009
Dear sirs , i have a epson stylus r230 photo printer,i am getting blank prints from my r230, its has new replaced print head, new data cables and i even tested labeled F1 and it is near the 3 tall blue...
take all cartridges out shut off then turn on make surethere is no obstructions where cartridges go replace them one at a time i found a piece of tape on mine would not print black and white removed it now it is fine
Jan 23, 2015 | Epson STYLUS R230 InkJet Photo Printer
Labels not moving forward enough
Check that you have activated tyhe right detection and not using continuous material in the driver. You should use Transmissive or blackmark depending on your labels.
Apr 16, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
Problem with my PC cant get mky printer to printer more than blank pages. Just bought new ink cartridges
Before fitting new cartridges and before removing them from their packaging give them a good shake.
If you think you have blocked nozzles stand the old cartridge in warm water.
Oct 22, 2012 | HP Officejet 6500 All-in-One Printer
This problem is with our church library Lexmark 1240 printer. We put a new black #17 inkjet in, but it prints only blank pages and we have 22 books awaiting labels. When I click on "print...
I believe this is a Lexmark X1240, THis printer is the same as a Dell A920, I do not have a manual for it but in the past I had a user with a similar issue. They had not removed the plastic from the ink cartridge before the inserted the cartridge. Please remove the cartridge and make sure all plastics from the nozzle area have been removed. If that dosen't work then try another print cartridge. Also visit the Lexmark website to make sure you have the latest drivers for the printer, this might resolve the "no labels" issue.
Hope this helps.
Mar 07, 2011 | Office Equipment & Supplies
Print on ribbon is 1/2 off label
check the driver (length and with) from the driver if is the same that the size from the labes that you have.print test page (print full label?) if not work, Reset to Factory Defult (Turn On with FEED and CANCEL buttons pressed, and relese after 5 seconds.
Oct 31, 2010 | Zebra S4M Thermal Label Printer
Have been using Samsung Label printer SRP 77011since last one year. Of late we have been observing that the print on the labes fade in a few days. What could be the cause and the possible solution for the...
Most likely it is a quality issue with the label you are printing on. As long as the image is printed good initially onto the media(thermal paper), the printer/software portion of it is done.
Thermal paper has a special coating and protective layer to prevent it from fading from exposure to heat, including light. But if the coating is bad then it'll show problesm like you describe
Apr 29, 2010 | Samsung BIXOLON® SRP-770II Thermal Label...
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Printing CD labels , can not get it to line up stright.
I have the exact problem with my HP Deskjet D2360...Done all adjustments, doesn't print in the outline of the label...help
Nov 09, 2008 | HP PSC 1510 All-In-One InkJet Printer
Zebra 110xi plus not printer strainght across label
* do full manual calibration
* reduce the print speed & try
* set back feed as before instead of default
* try with little big labes
Jul 28, 2008 | Zebra 110Xi III Plus Thermal Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
528 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
