Question about Hitachi 50VS69 50" Projection HDTV
The Tv turns on but there is no picture and than it sounds like a cd spinning inside than it shuts off
  • 336 Answers
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Was the fan was running ok? You can clean it w an air pressure can. Part # is ux25951 for lamp you can find it here: http://www.discount-merchant.com/SearchResults.asp?Search=UX25951+?Click=48173 Have a blessed life!
Posted on Nov 18, 2009
Turn tv on no picture no sound a peircing sound comes out of the tv and power light shuts off
Is this a DLP?
If it is, it could be a color wheel motor bushing. They spin at about 1800RPM. When the motor doesn't come up to speed in time, then the controller will shut down. I don't think a fan could make a noise like that.
Jan 19, 2011 | RCA Televison & Video
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
When you turn on the TV it makes this buzzing sound like something is spinning inside the TV. After a while the TV cut off on its own. It has a new bulb in it.
check the fan that cools the bulb. if its rubbing something that would make the buzzing sound, and if its not cooling the bulb it will shut off when it over heats.
Sep 14, 2010 | Samsung DLP HL-P5663W 56" TV
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
TV has no picture, shut off in the middle of a show.
Greetings!
There's a part inside of your tv that over heat, when a minute comes it stop because of the heat. Better check with a tv technician or repair man before the damage became worse.
Thanks.
Nov 13, 2008 | Mitsubishi WD-52631 52" Projection HDTV
I have a 52" RCA
Check your DMD board fan. Make sure it is spinning. This fan is the #1 problem for this model not turning on. This fan keeps the DMD board cool while working and if the fan does not spin your TV will not turn on. You might need to replace it if it is not spinning. If the fan is spinning, then check the color wheel. If it is not spinning your DMD board is not working and should be replaced.
Mar 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Power
  • Sorry but it can't be fixed without knowing how a tv works on the inside. The problem is on the inside possibly in the horizontal section and should be taken to a repair shop
Dec 31, 2007 | JVC AV-32730 TV
No Picture, no sound, spinning up noise
vertical ,horizontal or power suppy
Dec 02, 2007 | Sony KV-32FS13 TV
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
207 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
