Tried to connect my NX6310 to my printer which is a HP All-In-One series 6300 BT. Printer will not work and I used the cable USB port to USB port and picked up new drivers, Microsoft Professinal, XP
    Problem Solver:
  • 6 Answers
The trick with windows XP, most of the time is to install the drivers first and wait for the software to ask you to plug in the printer. Try removing the printer from your printer's folder if windows already tried to install it, reboot when it removed, then install the device drivers/software first and when asked...plug in the printer.
Posted on Nov 18, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Hp laserjet p1006 has stopped printing. When I connect usb-cable til pc, I get the msg: usb device not rekogniced
This may help. Before you disconnected the USB cable did you "disconnect" it using the icon in the system tray? If you did not, try cycling power to the computer with no USB cable for the printer connected. Sometimes when you unplug a USB cable while it is still "connected" to the device your computer will lose track of that USB port. I hope this helps you.
Nov 13, 2017 | HP LASERJET P1006 Printer
I have used the printer (hp deskjet f4180) for over a year now. but recently when I connect it to my pc (hp windows vita), i get an error message that the usb fevice is not recognised. I have tried to...
If I am right, the error message should be "USB Device is not recognized...." not "Fevice" :-). This happens with most usb devices when there's connection problem, i.e. the USB cables or the USB Ports or the USB interfaces.
First of all try the printer with the same cable on another machine to make sure it works, if it doesn't work, then you'll need to replace the USB cable or try with another cable.
You can also try cleaning he USB Ports and the cables usb jack with a brush dampen with alcohol. Also clean the usb ports on the computer with the same materials mentioned.
These will definitely help you find out the culprit and take the necessary actions, like replacing or switching the usb port.
To simply find out if it's the computer or the printer or the cable, try the printer on another computer.
Note: If it's not recognized once it's connected, then the issue is not with the drivers... If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | HP Office Equipment & Supplies
My printer does not work. It is on and connected to a USB cable but will not print. It always queues all of my print jobs. I tried to reinstall and it tells me there is no connection between my computer...
Have you tried to print a test page? Is the USB cable good? How about trying a different USB port. Also have you tried to use the printer on another PC? If you have another USB device, such as a flash drive or mouse, try it in the suspect port. If still no luck and the printer doesn't work on another machine, then you're looking at a defective printer.
Nov 27, 2009 | HP Photosmart C6280 Printer
I have an hp laserjet 1000 series and it is not connecting to my computer
Most probably you have either a defective USB cable, or the USB port on the computer is not working properly. To separate the cause of the problem, first try to use another working USB cable to connect the printer to the computer & see if this works.
Oct 25, 2009 | HP LaserJet 1000 Printer
My hp 6300 AIO printer is "offline" and will not print
go to printers icon there you will see HP Officejet 6300 icon right click on it and select use printer online..if you dont get the option of use printer online then unplug the USB cable and turn off the computer..wait for 2mins and then turn on the computer..wait for the computer to get completely reboot..in other words you should not see any hour glass..then connect the USB cable..wait for 5mins and then try to print..that should work
Mar 08, 2009 | HP DeskJet F380 All-In-One Printer
My Hp Officejet 6300 All-In-One printer will not copy
printer is offline yet cables are connected and printer was working a day or so ago!
Jan 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
Large data transfer laptops, cable, or USB adapters DELL Lat-C
the system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Nov 23, 2008 | HP Pavilion dv9000z Notebook
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
