Question about Maxtor OneTouch II external hard drive 300GB 7,200 RPM - FireWire & USB (E04W300)
Maxtor 300GB--can't delete or write
I have a fairly new Maxtor external HD 300GB and used it only with a single PC for several months. I've switched to a mac powerbook and although the computer recognizes it, I can't delete anything from it or write anything to it--the message is that it "can not be modified". Help!
  • 317 Answers
IF the drive is formatted as an NTFS File System, any and all Mac Computers will not allow you to write or delete any files. The Simplest solution, is to search Google for a program called "MacFuse" it is a totally free and totally safe program that will allow you to use the drive like normally, without having to reformat it.
Posted on Jan 10, 2008
  • 589 Answers
You didn't specify if the original PC was Windows or MAC.
Is this USB external used on a PC with Windows? If so is it formatted NTFS? If so, Mac OSX and pretty much everything else but windows NT, 2k and XP can not write to NTFS. OSX and Linux will read an NTFS partition but at this time not write to it. If your drive is formatted NTFS, I would say, go to a windows machine and convert it to a FAT 32 Partition. Most everything will both read and write to FAT32.
I have unplugged my maxtor 300gb external hard drive from one pc and have plugged into my laptop to transfer data. Light goes on but doesnt seem to be showing up on laptop 'My Comp'
you might want to try to unplug to HD's power and plug it back in then plu the USB into you computer....make sure that you remove the usb safely and not just unplug it.
Nov 24, 2010 | Maxtor OneTouch II external hard drive...
How to move large data blocks from one PC to another using Maxtor external hard drive
just right click the folder you wont to move and send to the maxtor drive
right mouse click and sent to
Dec 26, 2009 | Maxtor OneTouch II external hard drive...
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
Maxtor 300Gb 6L300SO Internal HD
I had a similar problem a month ago. Go to the Seagate site(They own Maxtor now) Click on the Customer Service and support link, then the warranty link. Supply the serial number and they'll give you the warranty info. I got an RMA number from the site, and received my (Refurbished) drive in about 10 days. They supplied a box to return the original drive, and I apid the postage. A very quick, easy and satisfactory exchange.
Aug 09, 2007 | Maxtor 300GB Ultra16 Kit 300GB 7200rpm...
Maxtor OneTouch II external hard drive 300GB 7,200 RPM - FireWire & USB (E04W300) Logo
186 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
