Question about Remington Garden
Chain sproket bad
Chain slips
  • 1 more comment
  • dontbother10
    dontbother10 May 11, 2010
    Remington.comhttp://www.desaparts.com/index.htm I hold little hope. Try an Internet search for "Remington YourPartNumber" I've had little success. Lou
  • jim gleason May 11, 2010
    Sounds like your sprocket is worn out/
  • dontbother10
    You provide no model number. Are you aware they are no longer in production of anything except disgruntled customers? Most replacement parts are long exhausted. Lou
  • 169 Answers
Replace the sprocket. may need a new chain as well
Posted on Nov 19, 2009
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
Chain is sticking to back sprocket and making my bike **** when i accelerate
Sounds like the chain is worn out and needs replacing if there is no more adjustment!
A good idea is to replace the sprockets at the same time, as they wear along with the chain, and will cause a new chain to wear out sooner.
Nov 19, 2013 | Suzuki RF 600 R Motorcycles
Knocking noise of chain in honda dream yuga bike when accelerating after shifting the gears. i have tightened the chain but still it happens.
That knocking noise could be that the teeth on your main drive are worn out and chain is jumping them on acceleration.Pull th primary cover and check the drive gear for chain on motor sprocket.Replace it if worn to that point.
Oct 02, 2013 | Honda Motorcycles
Motor runs but chain is static can get it to go if I pull the chain round by hand but any resistance and the problem returns
Clutch slipping due to wear, or the sproket teeth have worn to the point that it is slipping in the drive links of the chain, i have seen the teeth/spline on the sprocket drum become unbonded, so the drum tuns but the teeth/rim does not.
Oct 10, 2011 | Garden
Having problems getting the chain back on.
What sort of problems?
Slacken off the adjusters, slip the chain onto the rear sproket and adjust the slack.
Jul 23, 2011 | 2002 kawasaki ZX-6R
Popping noise coming from front sprocket when wheel is turned on 01 suzuki gsxr 600
hi it sounds like your front sproket is really worn and hooked when you turn the chain its not releasing the links smoothly ,replace it with a new one and check the condition of your chain it may be worth replacing a complete chain and sproket set as running a bike with a worn front sproket could lead to a back wheel locking up at speed if the chain jams
Feb 22, 2011 | 2001 Suzuki GSX-R 600
The chain on the MX500 dirt bike is slipping over the sproket on the back wheel. I've read the posts where the sproket turns but the wheel does not, that is not my issue. I'm thinking I just need to...
Is there a chain adjustment on this bike? It must be very loose to slip over the sprocket. See if there are two bolts that act as jacks to move the rear wheel back away from the drive sprocket. Loosen the locking nuts on each bolt, and tighten both equally until there is only 1/2 inch of play in the middle of the chain, then repost.
Gary
Dec 22, 2010 | Razor MX500 Dirt Rocket
Chain seems to be installed correctly but when I start to cut the chain slips and stops it is properly tightened and pulls easily by hand
You need to inspect the sprocket for wear. Many time the sproket will get a groove worn in the theeth. When you're stopped, and on the normal teeth all is well. If you begin to cut and the chain moves into the goove it's suddenly loose. Replace sprocket and chain and you'll be sure they fit .
Jul 21, 2010 | Garden
6.5L turbo diesel engine diagram, for timing chain installation. I think I need a timing chain or lower sproket because whill taking out the Injector pump I notice the gear the pump attaches to would spin...
95 chev 2500 turbo diesel that overheats. No oil in water or vice versa. New radiator, thermostat. Have flushed the entire system. Water pump does not leak & seems to be working. 187,000 miles. I love this car and want to fix it. Phil email: certispec2us@yahoo.com
Dec 29, 2009 | 1995 Chevrolet Suburban
Engine still cuts out and backfires after changing coverter
This seems to be a timing problem. backfiring usually means that the timing is off. The timing belt sproket could have worn off or belt its slipping.If your car has a timing chain that could have broken sprokets. Timing is usually the culprit here in cases like this.
Jan 21, 2009 | 1992 Chevrolet Lumina APV
Garden Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
