Picture forming concentric rings of colours - green, surrounded by blue, then red halo. What is the cause and what do I need to do about it? Thanks
  • Lavell Turner
    Lavell Turner May 11, 2010
    What is the model and make of the Set? Sounds like you have a convergence problem. But need more info from you as to the make and model of the set.
  • 336 Answers
If its a Dlp . Hi,its sounds like an issue with the dmd.This is how the dmd works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd is a chip that carries 2 million pixels that create the image and colors .When its bad it will cause pixilation,color discoloration or stripes.God bless you! Ifa Lcd.it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact the maker or look for your light engine online.
Posted on Nov 19, 2009
Rca wire colours are
The most common colour convention is:
Yellow: Video
Red: Audio, right channel
White (or black): Audio, left channel
Green; Centre audio
Blue: Left Surround
Gray: Right Surround
Brown: left back surround
Tan: Right back surround
Purple: subwoofer
Sep 13, 2013 | Car Audio & Video
My mitsubishi vs 6047 has been in unheated storage for about 4 years. now picture is very blury. when words are on screen large letters are legible with small white horizontal lines dancing side to side....
Does the picture look like this?
If so I believe your CRT liquid coolant has gone bad and needs replaced.
How to diagnose bad CRT Coolant:
Note: This problem will only affect the GREEN and BLUE picture tubes. The RED CRT is never affected, because the wavelength of the red light does not promote this algae growth
General Symptoms: Washed out, blurry picture, red portions mostly OK, GREEN images have halos, BLUE portions of images may have halos or be missing entirely.Turn the color level control all of the way down and remove the screen and/or the cabinet that contains the mirror. (different for different models) Do not turn the set off or the color level control will reset to preset levels. Look directly into the picture tube lens while the set is on. First look at the RED CRT. Observe the scan lines in the picture. These same lines should also be present in the green and blue picture tubes.
After looking at the RED CRT for comparison, look into the GREEN or BLUE CRTs. If it is contaminated, it will look like there is a layer of film that you have to look thru to see the picture. There may also be swirls and other various contaminates forming. If it is not as clear and sharp as the RED CRT, it is contaminated, and you should change the coolant fluid. IF you wish to tackle this I will supply more information and instructions. This task is medium to hard for non trained people.
Let me know if you wish to get the instructions on changing the fluid.
Jun 09, 2011 | Mitsubishi VS-6047 60" Rear Projection...
All of the people are red and I have no blues and green
This is a fluid problem...in the lens...
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2010 | Philips 55PW9363 55" Rear Projection...
Colours red and green are out of sync
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2009 | Philips 55PP9363 55" Rear Projection...
Philips - Magnavox Model # 9P6034 C103 Picture problems? Please Help
1 5 oz bottle should be enough for each tube. The small picture is caused by bad opto-couplers on the large signal board. Let me know if you need more info on the couplers and where to get them
May 15, 2008 | Televison & Video
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
