Question about Samsung HL-S4266W 42" HDTV
It keeps turning off and the three lights come on in the front
My furnace the burners light and come on and heat up the unit. But the fan never kicks on and blows. The fan itself works because I can turn it on manually so I know it's not that. The trouble code...
The manual selection on the thermostat bypasses the fan relay. When in Auto, the fan relay turns on the blower. You are probably looking at replacing the circuit board. As far as the three blinks, on the reverse side of the front panel there is a wiring diagram and error code chart. It will give you a starting point where to look for a problem. The three blinks could indicate an open limit because the blower is not operating. Keep the blower on manual and let the furnace run normally until you can figure out what the problem is.
Feb 23, 2011 | Intertherm Heating & Cooling
I have Sony 40inch breviary. My tv is not turning on I reset tv but it still not working. Stand by light keep blinking but tv is not turning
Hello
Blinking of standby light in Sony telivisions are fault indications. You just count the number of blinks occur at a time when the set is switched On with its FRONT PANEL POWER SWITCH. Count it three or more times, and make sure about its number of blinks and inform me through Fixya. From that number, I can get into the fault section, sometimes more accurate to the location of the fault. Count it Keenly for at least three times and make sure before reporting. OK.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Changing the headlight on a 2006 pontiac g6
To replace the headlight bulbs.You need to remove the head light assembly out.The head light assembly is held by 2 to 3 three screws on each side. You need to remove those screws first.The front trim will get loose,the front trim is held by pins.The pins are of plastic and easy to release.Just release this pins and the front trim will get completely loose and can be easily taken off/. The head light assembly is in the front fender.Once the front trim is removed the head light assembly can be easily removed from front fender compartment.If its bit tight there,then you can use a screwdriver to give it a pull towards out.The head light bulbs can now be easily seen as well as easily removed now.Turn the bulb socket counterclockwise to remove the bulb from the bulb assembly. -------- Keep updated for any more queries.Thanks.
Oct 14, 2010 | 2006 Pontiac G6
Replace turn signal bulb
The procedure to replace the REAR turn signal light bulb is as follows:- 1) There are three wing nuts on the inside of the trunk for each tail light. 2) Remove the piece of plastic just inside the trunk where the latch is. 3)Then remove the two thumb screws that the cargo net is attached to and the piece can be pulled up. 4)Them pull the carpeting away from the area where the tail light is located. 5)properly remove the three thumb screws. 6) Keep the bulb handy so you can fit the new bulb as the old bulb is removed out. The procedure to replace the FRONT turn signal is as follows:-- 1) First remove the front headlight assembly.And the bulbs . 2) Open the hood to remove the headlight assembly. 3) Pull the headlamp assembly straight out from the vehicle (moving the headlamp up and down slightly may help to remove it easily). 4) Front turn signal is located below the headlamp assembly (turn/parking lamp on top and the fog lamp is below it). 5) Then turn the bulb socket 1/4 turn counterclockwise to remove it from assembly. 6)Then pull the old bulb from the socket and replace it with a new one. Thanks. you can rate this solution and show your appreciation.
May 21, 2010 | 2005 Pontiac Grand Prix
No picture on tv all three lights flashing on front of tv.
Three blinking LEDs mean lamp may be defective replace the lamp.
May 25, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLM437W won't turn on
my advice is that if the project is getting expensive kindly invest in a new tv. i am nt familiar with that set but you are having a micro processor problem replace it and your tv will work fine as it was before good luck.
Jul 18, 2008 | Samsung Televison & Video
Sanyo tv chassis 2111 Series EB5-W Dead
hi there, light flashes means a shorted parts at the power supply and mostly at the horrizontal sec,, it may need to check-up and repair., do some testing and check-up at the horrizontal section. ty
Mar 10, 2008 | Televison & Video
Samsung HL-S4266W 42" HDTV Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
