Question about Miele 24 in. G665 Built-in Dishwasher
Hi my miele dishwasher g665 no hot water or drying
Hi my miele dishwasher g665 seems to be working but does not heat water or dry please help
New heating element
Posted on Jan 27, 2010
  • ole_bendtsen
    ole_bendtsen Aug 20, 2013
    Does it need a new heating element or what do you mean?
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Nov 17, 2014 | Miele 24 in. G665 Built-in Dishwasher
Miele Turbothermic G579SC Dishwasher Intermittent Problem Dishwasher works fine on approximately 30 per cent of times it is used. This percentage seems to be about the same whatever program is selected...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 07, 2011 | Miele Dishwashers
There is no water going into the dishwasher even though the water supply is on.
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Miele 24 in. G665 Built-in Dishwasher
Miele dishwasher not heating
hi,
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Jan 05, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
Drying cycle problems
Take the door fascia off, and you'll see a pipe from the steam outlet to the Soap Dispenser in the door.
Take that off, and flush out the small bit of food that is blocking the tube.
Put the cleared pipe back in situ.
Run machine, you should get steam, and no water.
When it blocks again, and you get the water again, repeat unblocking process etc...
Jul 16, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele no heat
The last I checked, the G660 will not work for the G665. If you look under Applicances in your phone book, you will see several appliance repair places. Most of them can get you universal kits to replace this. I however caution however that you should really let a tech look at your dishwasher. Something tells me that boards got shorted out by mistake without realizing it.
Mar 10, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
1,364 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
