Question about Bose Lifestyle 12 System
Where can I buy a replacement rear speaker cable
Where can I buy a replacement rear speaker cable for my bose accutimass speaker system.
  • regjordan Nov 18, 2009
    Thanks, but I am after an original bose cable and connector.
    Sergeant:
  • 188 Answers
Al you need is twin core 1.5 mm cable, you can get this at any hardware store
Posted on Nov 18, 2009
How can i bypass the stock amp in a 2000 pontiac grand prix with the bose speaker system in it with out taking the bose speaker's out?
you can't. the bose system is just that, a system. you need all the pieces for it to work. the head unit doesn't have any power and you need the amp to drive the speakers. also, bose is a proprietary system. only bose parts will work for it. so you can't buy any amp off the shelf and swap it out. if the amp is bad you need to buy a replacement bose amp or replace everything with a new head unit and speakers.
Apr 12, 2011 | Car Audio & Video
I have a wireless speaker system that home base plugs into an external music source, can In somehow connect it to the Bose 3-2-1?
Yes, it can. The Bose rear panel has RCA jacks for right and left channel audio outputs. You'll need a connecting cable with RCA plugs on the Bose end, and whatever kind of input connector your wireless speaker system needs.
Jan 13, 2011 | Bose 3·2·1 Entertainment System...
My bose acaustimass 15 right front speaker and right rear speaker are both not functioning any help.
you cannot get help by this,. You should clarify your question. But for usual errors, check the cables and the connectors. Once i found the pin of my connector folded, and my speaker system was not working well. just check for it.. or just try replacing the chord.
Oct 31, 2010 | Bose Acoustimass 15 System
I need to move my subwoofer another 3 feet and don't have enough speaker cable that ends with the serial port. The cable runs from a fireplace mantle and through the wall. I thought I had enough cable, but...
Unless Bose offers a longer cable, which it doesn't sound like or they would suggest you buy one from them, your options are limited to splicing. Just make sure your connections are good and protected with electrical tape not duct tape or scotch tape. You can even use small wire nuts and electrical tape.
May 22, 2010 | Bose Cinemate Digital Home Theater System...
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
Trying to connect external speakers
check with radio shack to see if they have something that will plug into the rear jack of the Bose...and has leads that you can wire to your speakers
May 27, 2009 | Bose Wave Music System CD Shelf System
I'd like to add two speakers to my older 4 pin Bose 321 system. Can I buy adaptors to split off the two small front speakers to run two additional speakers to the rear of the room?
is there any connection for 2 more speakers?
if not there is no real way to make it surround sound . however you can double up the speakers with the front ones.
but you loose sound quality and it wont be true surround sound. but you can give it a try
Apr 21, 2009 | Bose Companion 5 Multimedia Speaker System...
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Bose Lifestyle 12 System Logo
533 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
