Question about Dell Inspiron 1525 Notebook
My power cord is not detected. I am plugging it in at a usual spot.
    President:
  • 1,149 Answers
Hi:
The power jack on your laptop is a common fail item, and often come loose from the system board. If it feels loose, and doesn't charge your laptop, first, have someone check to make sure the adapter is putting out voltage. If it is, there is most likely damage to the power jack.
Posted on Nov 18, 2009
My KitchenAid mixer died. It’s like there is no electric going to it. I’ve checked the outlets, GFI and the circuit breaker
Try plugging something else into those outlets and see if they work, or try plugging the mixer into an outlet that you know is working. If it still doesn't work it may be the plug on the mixer or broken wire on the power cord. Examine the power cord and look for any weak spots or damage to the cord or where the wires go into the plug. Usually the wires tend to break right where they go into the plug from bending or wear and tear. If that's the case all you need to do is buy a new plug cut the old one off and install the new plug.
Jan 26, 2018 | Electric Electrical Supplies
Cannot pull cord/ pulls easy when spark plug is out. Cannot detect fuel at spark plug, seems to be no spark. Had been using it without problem, then shut it off for a bit, now this.
Usually if you cannot pull cord with the Plug in it is because there is way too much fuel in the cylinder and that causes Hydralock. Does the cord pull at all? Something in the cylinder bumping up against the plug?
Nov 05, 2015 | Garden
Manual for my new refurbished acer computer
Look on the Internet for a manual for the machine. It sounds as if the power cord should go to a power block which you haven't got and which then plugs into the machine.
Is the Acer a PC or a laptop? PC power sockets are at the back, laptops ditto but are much smaller, usually round.
Dec 28, 2013 | Microsoft Computers & Internet
Rabbit chewed power cord. fridge not working. Need to replace. I have the back of the fridge open, cord leads to plastic box with wires, do I simply pull the wires out and go to hardware store for...
Do not simply pull wires out of box. It sounds like they go to the control board. There should be a spot to safely unplug cord from inside the plastic box. then you can go to local appliance parts store and get replacement cord. They may sell cord at local hardware store but usually their is a specific plug in and that requires the manufactuers specific cord. In some cases it will come with the wire harmess then you can cut and splice where needed with appropriate connectors.
Oct 26, 2010 | Whirlpool Gold GR2FHMXPQ 21.6 Cu. Ft....
I have a intel media series dp35dp motherboard. I have a power led cord, reset sw cord, power led cord, m/b sw cord and a speaker cord for the speaker on the chasis. When I plug them up I don't see a spot...
in newer generation motherboard the buzzer is built in in there is no need to connect an chasis speaker if built in buzzer is not there uwill find a four pin conecter near the power pannel you nedd to conect the pwer switch and reset switch in proper conector or the system wont powerup properly
Sep 25, 2010 | Intel Computers & Internet
Need a power cord
Most monitors take the same power cord as a desktop power supply or printer. They are available at most stores with computer gear. The monitor spot where you plug in the cord will be a irregular hexagon forming a regular rectangle on one half and three sides on the other. The monitor will have three prongs. The wall outlet plug is a standard grounded plug.
For a picture of the cable ends: http://www.superwarehouse.com/Cables_to_Go_6_FT_Universal_Power_Cord/03130/p/14181
I hope this helps.
Apr 12, 2010 | Liquid Video L17LCD2 17" Flat Panel LCD...
My Wii isnt powering on?? please help
Consider the following...
  • plug a lamp or another device that requires electricity into the spot the wii power cord is.
  • take the power cord out the wii, locate another wii power cord and try that one or vice versa
Sep 11, 2009 | Nintendo Wii Console
Lost cord
hi,
you can try looking at thrift stores, usually they have a "cord wall" or cord bin, that lexmark I believe has the power supply that kind of fits into the back of the printer so it should be easy to spot, but when you look at the power suppliy make sure it says lexmark on it before you buy it,
just an idea
J
Jul 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Dell Inspiron 1525 Notebook Logo
Alun Cox
