Question about Irons
Not getting hot
The Iron has stopped working and the alert light is constantly on.
The Iron i think is a tefal program 8 500.
  • 1 more comment
  • Anonymous Aug 22, 2008
    iron does not come on at all.
  • bysic51 Sep 30, 2008
    i lost my thermal fuse and i need to know at type it is so i can buy another one.
  • ashleyjp89 Nov 01, 2008
    exactly the same problem. i took back lid off it. you can disconnect the thermo, the only problem is that the negative wire goes through the thermo so if you disconnect it it dosent work. im sure theres a way round it. please someone help
  • 304 Answers
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Posted on Jul 24, 2008
Geo holker, i am having the same problem can u please tell the temperature type of the heat fuse because i lost it when i was gonna replace it, and i dont know wat kind it is. (eg. 50F degrees fuse).
Posted on Sep 30, 2008
    can u give me the type of thermal fuse of the steam press?
  • ever555 Jan 25, 2011
    I had to solve the same problem on Tefal Program 8 500/FV9250. I was told in the Tefal service to buy a complete new heating plate. The thermal fuse (tiny pewter rolling-pin) is not delivered separately. New plate cost about 35€. The cheap Tefal iron with two year warranty time is for less then 40€. I have modified the rolling pin, so my wife can use it again and in the worst case scenario will the fuse work properly again (at least I hope). The moral of the story is do not buy high tech iron. Buy just the cheapest one. The heating platform seems to be the same in all models. So does not matter how much it cost, in a short time after warranty time passed tell you good bye, with no chance for reasonable repair costs.
I have a tefal pro express turbo GV8150 and there is constant team coming from iron without me touching the steam button. Can anyone help with a diagnosis and or possible fix?
constant steam means the control valve is not working
descaling may fix the problem
the other fix is a new iron as the cost to repair is generally more that a replacement price
Sep 30, 2016 | Tefal Irons
Tefal problems
iron will not get hot but red light in on
Jan 15, 2014 | Tefal Irons
I have a Tefal Pro Express Turbo iron (purchased in 2005). In the past 2 days the steam is constantly on - the button does not appear to be stuck. I can't get the steam to stop... unless I take out...
Yes, if your electric cord was extremely hot to touch is not common. It's posing danger to your unit and to your entire electrical system that may cause fire. Please let a qualified electrician inspect and repair your unit. The unit thermal fuse may not functioning that automatically switch off or cut the electric power of your unit when it gets too hot. Thank you for asking.
Jun 14, 2011 | Tefal Pro Express GV 8120 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
My tefal express 2941 steams constantly when switched on and cannot be stopped, please advise?
Fill the iron with 50/50 water and vinegar and let it steam for as long as it will. This will clean out the iron thoroughly, the green light will stop flashing and it will go back to normal. Then remember to clean your iron on a regular basis. Mine did!! Found this solution on another site
Feb 20, 2010 | Tefal Irons
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 16, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Pro Express - Constant Steam (Model 2932)
Great answer from Jacquief above. To which I add try giving the base of the iron and its button, a very light tapping with a tack hammer (much smaller and lighter than a standard hammer) wrapped in a tea-towel. This can often break up the lime scale seal which has formed somewhere inside and is not responding to Jacquief's method. In future never use scale laden tap water in your iron, use $2 litre bottles of distilled water from any supermarket.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Irons Logo
805 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
