Battery light came on my 97 2wd rodeo while driving and the vehicle died. replaced alternator and fixed problem but the battery light is still on, how do i get this to turn off?
    President:
  • 1,146 Answers
Hi:
The battery light is trying to tell you that there is a problem with your charging system. Since you have a new alternator installed, I would have your battery charged and tested, then carefully check all of your connections to make sure everything is clean and tight. Hopefully you should get rid of your battery light..
Posted on Nov 18, 2009
My 1992 isuzu rodeo 3.1 2wd m/t has my batt. light coming on and off,when the dash light comes on my lights will
I would have everything tested first. Thats usually free at most auto part stores. It does sound like your alternator is starting to fail or possibly your battery.
Feb 02, 2012 | 1992 Isuzu Rodeo
Dash lights come on..mph gauge went down..radio cut out..loss of power in engine..kills batterie. While running, removed pos. batt. cable and engine died. Altenator problem??
You need to replace the Alternator. The vehicle died because you removed the power supply to all the accessories, if you remove the Negative cable and it dies then you know for sure it is the alternator. that is an old shade tree way to test the alternator.
Apr 05, 2011 | 1996 Isuzu Rodeo
Car died on the freeway and cant get it to start again. Its been a couple of days when I stick the key in it makes a clicking sound and now my lights wont even turn on
You first have to make sure the alternator has not failed. Try to fully charge the battery and see if the truck will start. If it starts, remove the battery cables making sure they don't touch the vehicle. If the truck shuts off, the alternator has failed. If it remains running, turn on the head lights along with other accessories. If it shuts off, the alternator still may be weak and needs replacing. Lastly, have the battery load tested to ensure that it still holds a proper charge.
Apr 23, 2010 | 1999 Isuzu Rodeo
Check guages light comes on after short drive while engine is running, and the car died while driving on I-95 the lights started flickering getting dimmer. the radio would turn off when anything else...
It sounds like the Alternator is actually bad.
One great way to determine this:
Recharge the new battery with a trickle charge overnight. Make sure use remove the wires going to the Battery before recharging.
Replace the Battery Wires.
Get the Vehicle Started.
When it has Started: Leave it Running and Disconnect and Remove the Negative side of the Battery. If the Vehicle dies, it is the Alternator that is bad, and needs to be replaced..
The Battery starts that vehicle, and provides nominal power to certain accessories. The Alternator actual Runs the Engine and Recharges the Battery with a low trickled charge.
Jan 05, 2010 | 1988 Chrysler LeBaron
I have a 2003 Toyota Tacoma and recently my battery light came on. I continued to drive and the power to the vehicle grew progressively weaker. I managed to get it home before it completely died. After...
To find out if the alternator works or not. First, start your car let it run then disconnect the battery(both cable).If your car still running your alternator good, your car die out alternator bad.
Aug 03, 2009 | 2003 Toyota Tacoma
1997 Isuzu Rodeo 2wheel drive. Repalced
Get a Beck Arnley alternator. The auto-zone, Napa etc. alternators are a problem for Isuzu's. I worked at a dealership and a lot of them came in for this problem. If you still have the original have it rebuilt. Check yellow pages.
Apr 25, 2009 | 1997 Isuzu Rodeo
Cruise causes surging, vehicle does jerky lurching
Get a good alternator not a cheap one.
Apr 21, 2009 | 1999 Isuzu Rodeo
Battery light came on then lights went out and van died minivan
your alternator most likely went bad and you were just driving on battery power with out the alternator recharging back the battery when your voltage drops to around 7.5 volts then the van will die please dont try to drive home with out fixing alternator.
Mar 22, 2009 | 2000 Chrysler Town & Country
22 people viewed this question
jasbo
jasbo
