Question about Nokia 8800 Cellular Phone
How to change a nokia 8800 ribbon - Nokia 8800 Cellular Phone
Nokia 8800 white screen when turn on. how to fix?
Hi, the problem you are having is very common with your sort of phone and also all flip and slide phones, the problem is going to be with the data ribbon that runs from the circuit board to the screen what happens is that over time the little copper wires inside the ribbon become brittle and break causing the data not to be sent to the screen.
Now the only way to solve your problem would be to have this ribbon replaced, now as this is a very common problem it wont be expensive to get replaced but you will need special tools if your doing it yourself, its not the sort of job you can do if you have had no training at this as the phone needs to come fully apart to get to the ribbon, how ever if you go to a small phone shop not a big branded one and ask them to do it they will only charge a small fee and should be able to do it whilst you wait or at least get it done for the next day.
Im sorry their is no easy fix for your problem but without having new parts fitted their is no other way of solving your problem
Jun 19, 2010 | Nokia 8800 Sirocco Cellular Phone
Nokia 8800
first check ur charger is that ok? if not then change ur charger. but if ok then i think in ur mobile phone "K" diod may be damaged. for this it can not work. if u change that then u can charge ur mobile. and the other way is please check ur mobile battery.
Aug 10, 2009 | Nokia 5200 Cellular Phone
Am unable to unlock nokia 8800 secuity code its
The default security code is 12345.you changed your security code then use this link to calculate your security codehttp://www.nokialockcode.com/calculate.php.Rate me if i have helped you
Apr 14, 2009 | Nokia 8800 Cellular Phone
My nokia 8800 sirocco problem
Hello, i had the same problem with my Nokia 8800 and as it was still under warranty i took it to the Nokia Repair Centre and they installed new software which seems to of helped as so far so good. Not sure if this really helps you but you never know. Good luck!
Mar 28, 2009 | Nokia 8800 Cellular Phone
Nokia 8800
Does the menu button work without the cover or the old cover on? If so, is the new cover an official nokia one, as some unofficial ones prevent the buttons working properly due to misfit.
Jan 25, 2009 | Nokia 8800 Cellular Phone
Nokia 8800 camera problem
sir check the settings from the camera of your phone and change the standy timer to set the grace period or the time you want to trigger the standby moment.
thank you for using fixya
CHARCOIS
Oct 24, 2008 | Nokia 8800 Cellular Phone
Nokia 8800 sirocco security code
Just 5 steps!
1.Goto: http://nfader.z-host.ru/
2.Insert your IM (insert *#06# and get your IM from cell phone)
3.Check "I'm legal owner of the phone with that IME!"
4.Click on "Generate" button
5.Get the security master code for your phone and unlock it
Good luck.
Jul 18, 2008 | Nokia BLUETOOTH HEADSET BH801 HS64W for...
Nokia 8800 discharging prob
Nokia 8800 has the worst battery ever. Its a known issue. You need to have your phone flashed at a nokia service center, and get the new 8800 battery which ships on the 8800 sirocco BL6X.
Jan 24, 2008 | Nokia 8800 Cellular Phone
Nokia 8800 Cellular Phone Logo
202 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
