Question about Poulan Oregon Chainsaw Chain For Chainsaw 18" Bar Length 64 Drive Links 3/8 Standard 0.05 Gauge Chiesel Chain
Wat are the settings on the high low screws, poulan chainsaw
    President:
  • 2,220 Answers
1.5 CCW from lightly seated, then tune for performance not sound. The more CW the leaner, it runs best just before it ceases. Clean air filter, Fresh 50:1 (1 gal premium to 2.6 oz quality 2-cycle oil) mix, at operating temperature. HTH
Lou
Posted on Nov 19, 2009
What is the high and low adjustments screws should be set I just put on a new carb on poulan 50 cc chainsaws?
This should be set using a tachometer, but to get the unit started you can lightly seat the "L" screw and back out 1 1/2 turn then lightly seat the "H" screw and back out 1 full turn. Then have the rpms set with a tachometer to 2700 idle and 12,000 - 12,500 wide open throttle.
Apr 09, 2017 | Poulan Garden
How do you adjust the idle on th poulan p3314 gas chainsaw and is there a special tool you need it just wont idle
Most poulan chain saw have three screws idle, high, and low.. if you look air filter cover you will usually see three holes and the high and low will usually have plastic covers on it.. adjust the low 1/4 of a turn and the idle screw in about 1/4 or until the idle picks up... On the plastic cover where the three holes are you will see H which is High L which is Low and I which is Idle... Let me know if you have any problems.. thanks
Jul 16, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
What are the high and low carburetor settings on a poulan 3416 chainsaw?
are they two separate screws? one for fast, one for slow.for the slow setting, first start the saw then screw until motor runs smooth without chain moving....if to slow the motor will stop....for fast screw....rev motor flat out then adjust so it screams its head off so to speak....it will need all its power for cutting wood so don't think you are opening it up to much as its designed for it.
Jul 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
May 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Apr 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Jan 27, 2010 | Poulan Pro Chain Saw 46cc 20"
What is the proper setting for the hi low idle screw for a poulan 2000?
the setting is aprox 1 1/2 turns on low idle and aprox 1 1/2 to 2 turns on high
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Set fuel mixture with high and low
starting settings are 1 turn on high side and 1 turn on low side.most likly you will be at 1 1/2 on low side and 1 1/4 on high side
Dec 21, 2008 | Garden
Poulan Oregon Chainsaw Chain For  Chainsaw 18" Bar Length 64 Drive Links 3/8 Standard 0.05 Gauge Chiesel Chain Logo
214 people viewed this question
Top Poulan Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Poulan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
