FixYa.com
Tags:
Wireless Adapters
Generic problem for all Wireless Adapters
Setting was disturbed
posted by ASHISH PANDE on Jan 10, 2008
SIR,I M NOT GETTING THE RUNNING SHARE MARKET ,AFTER LOGING MY ACCOUNT ,HOW CAN I CHECK THE SETTING FOR IT,FOR LOG THIS ACCOUNT TO RUN JVM IS MUST I INSTALL IT ,THE ACCOUNT IS OPEN AFTER LOGIN,BUT IT DOES NOT SHOW THE RUNNING MARKET,PLS SOLVE MY QURY NOW
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 30, 2008
Not Rated (0)
Technomancer
Rank:Wiz Wiz
Rating: 84%, 13 votes
Hi Ashish,
First off, if the program that you wish to run requires JAVA (you will know of this if you see a empty screen with a inlaid box and a small "x" in red on the top right hand corner of that inlaid box). If it does, that what i can suggest is that you install Java from java.com (if you're the administrator or power user of the computer you're working on).
Another alternative is to let ensure that your ability to run active X material is enabled and not checked off. You can check this via these steps:
1. On the internet browser clikc Tools> Internet Options> Advanced tab> Browsing> check all.
Also, make sure that the option to use java is enabled. Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP (325526-001) (325526001) 802.11g/b Wireless Adapter Motorola (501754-001-00) 802.11b Wireless Adapter Motorola DC800 Wireless Adapter Sony (PCWA-C100) 802.11b Wireless Adapter Sony VAIO PCWA-C150S 802.11b Wireless Adapter 2wire (1000-100016-002) Wireless Adapter 3Com (030110000) Wireless Adapter
Can you Help with these Wireless Adapters problems?
Lexmark N4050e 802.11g Wireless Print...
slow printing- suspect wrong...
what is the latest driver for... Answer This...
2wire (1000-100052-000) 802.11g/b Wireless...
connecting to internet
I called embarq and they told... Answer This...
NetGear WG111T 802.11g/b (E82321) Wireless...
Hello, i need to know my...
can u help me Answer This...
Linksys WUSB54GSC Compact Wireless-G USB...
set up cd
the setup cd does not load Answer This...
Microsoft Wireless Network Adapter Xbox 360...
wireless adapter
i have the wireless adapter but... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
