Question about Sharp Microwave Ovens
Door won't lock on Sharp Half Pint microwave
The door to my sharp half pint microwave won't latch closed and therefore the start button will not work.
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Sharp half pint
The fuse should be located on an input line filter board INSIDE the microwave. You will need to unplug and remove the outside case to get to it. Simply follow where the power cord comes in and you should see a fuse mounted on a small circuit board somewhere. This is the line filter. The fuse should be a 20 amp appliance fuse that you can purchase at any hardware store. DO NOT attempt to re-energize the oven with the cover removed. There are dangerous voltages present in the high voltage circuit (about 13,000 - 14,000 VAC). Put the outside case back on before trying an op test. Let me know if this helps.
Posted on Aug 11, 2007
heatman101
  • 43501 Answers
SOURCE: sharp half pint microwave wont heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 08, 2010
jsrock516
  • 5911 Answers
SOURCE: I REQUIRE A WAVEGUIDE COVER REPLACEMENT SHARP
Here's a link to the parts listing at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R120DK/0958/0123245?searchedModel=r-120d&blt=
The list also includes helpful schematic diagrams that you can print for future troubleshooting.
if you need further assistance, please post back and let me know. I hope this helps you.
Posted on Nov 03, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: the digital display no longer
On this model, it's usually not economical to repair, but in most cases it can be repaired for $39.95. Details are here.
Posted on Oct 06, 2011
The digital display no longer works on my sharp half pint microwave r120d. How can I fix this? thanks in advance.
Aug 16, 2011 | Sharp R-120D Microwave Oven
Nov 03, 2010 | Sharp R-120D Microwave Oven
Sharp half pint microwave wont heat
heatman101
Sep 08, 2010 | Sharp R-120D Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Dont know how to get it working
You may need to open and close the door first.
Press CLOCK > 1 > 2 > 3 > CLOCK.
Let us know if this doesn;t work. You may have a bad door switch or mount.
Nov 30, 2008 | Microwave Ovens
Front door closes on a model R-1610-11-12 but light does not go out and microwave cannot be started up. Door does not seem to latch in place. In lower door latch inside the microwave I can see a plastic...
hi check that the door catch is locking into place maybethe locking mec is not engaging or triping the micro switch ,if it does n't trip the switch it won't turn light off and unit won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Sep 14, 2008 | Sharp R-1870 Convection/Microwave Oven
Display shows nothing, microwave cuts off
You need a couple of cheap microswithes that the door latches hit when you close the door and a new control for your display problem which sharp has had a problem with
Oct 30, 2007 | Sharp R-1405 / R-140 Microwave Oven
Sharp half pint
Aug 11, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
202 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
