Question about HP Compaq Presario S5200NX (DM173A#ABA) PC Desktop
Compaq Presario S5200NX on/off button is slow and needs to be pressed a number of times before start-up. Can this button be replaced or is there another problem
    President:
  • 1,149 Answers
Hi:
I don't suspect the button is the problem. unless you see physical damage to it. Take off the side cover and examine the motherboard. Look for any capacitors that might have leakage..(capacitors look like little cylinders ) Often they get puffed up and have a brownish residue on the tops. If so, you need to back up your stuff, as your motherboard is on its last legs.
Posted on Nov 18, 2009
  • 65 Answers
I belive the button can be replaced, if its an older computer it could prove difficult to find that particular button though
I have a compaq presario S5200nx I have no task bar,all programs, or log off. I have to manually shut off the computer. all other functions seem normal. I suspect the video card ,as for awhile when I...
Hi ,
Ok , lets go to your control panel and find the recovery icon , press on that icon and do a recovery of your system , also check screen res. to make sure your settings are ok , let me know if this works for you if not i will advise futher Good luck Roy
Sep 04, 2011 | Compaq Presario 5000 PC Desktop
Date and time does not stay after shut off it goes back to 2001
It think your cmos battery is die and you need to replace it ...that's what the cmos battery is for.... to save the time and bios settings.....
Apr 06, 2011 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Have a HP Compaq Presario S5200NX and no power. I think it's the memory, because the one that;s in the machine is a SDR and it should be a Dimms. The little button in the back of the machine blanks
OK, you would get a beep code with bad ram. There are safeguards on the sockets which prevent the wrong ram going into thr wrong slot. DDR2 have 2 blocks on the socket DDR1 have One, SDram have one but it is offset from DDR1.Try to count the gold fingers on one side of a Dimm and that will tell you if it's a 184 or a 2xx ( I forget ) . Did the machine ever work in this configuration?
Apr 11, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Beeping upon startup and nothing else.
You need to check the RAM that is the first causes of beeping your system unit. Try to remove the RAM and clean the dust and re insert it. Try to use the other memory slot. You can try it 3 times. Thank you!
Jan 23, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Compaq Presario S5200NX will not recognize memory stick
is either you reload the computer system or u buy an internal or external usb card.or check the connection cable inside the computer machine if it is properly connected
Jan 16, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
CPU Fan going out for cOMPAQ Presario S5200NX. Need a new 1. Can't find it. Where can I get 1
i can sell you the cpu fan for 15 usd but pls tell me your location because i'm from the philippines. will you shoulder the F&H
Jan 08, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
COMPAQ PRESARIO S5200NX WON'T START - Press start button, led's light up for about 5 seconds - hard drive starts to spin, then led's go off and every thing shuts down. Power supply is ok (swapped power...
Hi:
Since you swapped the power supply already, and have disconnected the DVD, CD, and floppy, that leaves the hard drive and motherboard!
Look the motherboard over, and see if there are any capacitors that are bulging or leaking out on the tops.
Is the inside of the computer very dusty? Check and make sure when you power up the tower, that the cpu fan is spinning up.
Your CPU could be overheating, so removing the Heatsink fan and re applying thermal paste is an option too
If it is, try resetting the CMOS on the motherboard, or pulling the CMOS battery for a minite.
Do you get anything to display on the screen?
If you have more than one stick of memory, take out one of the sticks if possibleif possible.
Nov 06, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Windows recovery on Compaq s5200NX
If the machine shipped with a recovery partition, while the machine is booting up, pressing either f1 or f11 should take you to a menu to launch from the recovery partition. Just follow all of the prompts and you should be good.
Aug 17, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
HP Compaq Presario S5200NX (DM173A#ABA) PC Desktop Logo
123 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
