Question about Acer Aspire L100 PC Desktop
Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
  • sguler Nov 18, 2009
    ok....do you think its worth changing the fan before i reinstall the operating system.
    as soon as i turn on the heat sinkk starts to get hot.
    the battery for the motherboard was alsoo completely dead, soo i replaced that today but no joy!
    i take it that the backup disks i created when i first brought the computer are what your talking about??
  • 65 Answers
The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
Posted on Nov 18, 2009
Acer aspire 5630 doesn;t start. problem with the monitor and the fan any solutions
If the fan is not working, your computer will not start sometime. Try cleaning the fan with hand held vacuum cleaner. and restart the computer. Before you clean the fan, remove the batteries and power cable from the computer.
Oct 25, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    The acer l100 does not power on at all no lights or fan running
    If the computer is not starting then and the power supply is ok then you need to try a different charger. If the problem still exist this may a sign that the motherboard is dead and need to be replace, because when a motherboard is dead it the computer will not receive any power.
    Thank you
    May 16, 2010 | Acer Aspire L100 PC Desktop
    After the electricity fail, my Acer Aspire L100 will not start, What could happen?
    2 things could have happened, a brown out and a surge a surge (usually what we fear the most about) will spike send electricity up to the computer destroying it, there is also a brown out, a brown out is when the electricity suddenly drops with out a single warning or notice, this can damage your computer very badly call acer, they should be able to fix it idk if its free or not but it does not hurt to ask.
    Feb 07, 2010 | Acer Aspire L100 PC Desktop
    I am running Wxp on my Acer L100. After about 15
    first things first pls check if the cpu fan is seated properly.
    if not pls try to reseat the cpu fan, but before doing it put thermal paste on top of the cpu to haver a better contact on the cpu
    if the fan is seated properly check the rpm of the fan on bios mode see if the rpm of the fan is fast enough.. if not then there's the problem.
    this things only happens if the cooling system of your processor is malfunctioning. Your built in hardware monitor tends to turn of the computer to prevent further damage,,
    Jan 11, 2010 | Acer Aspire L100 PC Desktop
    HI THERE, MY L100 DOESNT WANT TO START UP. ON START UP THE SCREEN SAYS MEDIA TEST FAIL, CHECK CABLES AND THEN ASKS FOR THE CD DISK TO BOOT UP. I HAVE OPENED IT UP AND IT SEEMS THAT THE FAN DOESNT SPIN. ANY...
    Sounds like your hard drive might be bad, its also possible that your cables are loose, follow the cable from your hard drive to your motherboard and make sure they are plugged in securly. If they are and your still haveing the same message then its possible that your hard drive is bad or at the very least that somehow the operating system has become corrupted. If you have the software that came with the computer, then you will need to reinstall the operating system.
    Nov 17, 2009 | Acer Aspire L100 PC Desktop
    Power but no display acer aspire L100
    Try these sequence(you need another one good computer to test and interchange component and you will find out the problem):
    - check your RAM, if you use two RAM start computer using one and interchange it to find out which one is bad
    - if your RAM OK, check your VGA
    - if your RAM and VGA OK, try to check your power supply, sometimes defective PS cannot supply sufficient power to all component to work.
    hope this will help you.
    Jun 07, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Computer wont start.
    Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective.
    Sep 18, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    106 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
