Question about LG enV VX9900 Cellular Phone
When I plug my phone in to charge it will not charge, why? It's the Enve2...
  • LG Master
  • 6,993 Answers
Can the phone on when you put it on? If the phone does not on, then maybe the battery cell is weak and cannot come up with a charger expect you charge the battery seperately with a desktop charger and the battery cell should come up by so doing. After which you can start charging.
If that's not the fault, check the charger, maybe it is no more working.
If it is not the charger, then the fault might be from the charging port.
If the fault is not from the charging port, it might be a software problem.
I believe you should find the fault if you follow the steps above. One of them should be the problem.
Best wishes.
Posted on Nov 18, 2009
Why wont my motorola photon q phone charge or power up...no green light comes on at all
Your charge cord may fit, but it may not be configured to your phone. I just bought a new Nexus phone that has the same charge port as my older Galaxy 4s phone. The Nexus charge plug fits into the Galaxy 4s charge port with no problems but does not charge after plugged into outlet. But the older charge cord will work with the new Nexus charging wise but data transfer will not work. So you may have a charge cord that plugs into phone, but may be configured differently due to phone manufacturer. Hope this helps.
Dec 19, 2014 | Motorola Cell Phones
My phone SE T303 ran out of battery so i plugged it in to charge, the red light came on. When I came to turn the phone on it didn't work. so i plugged in the charger without the battery inside, then put...
short answer is your battery is dead and needs to be replaced. It is hoped you didn't short out the charging port within the phone itself... It is doubtful but can happen..
Jun 02, 2017 | Sony Ericsson T303 Mobile Phone (Shadow...
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Huawei Impulse 4G
When i plug my charger in i have to move it around for it to start charging and if i move my phone it quits charging its not the chargers i have tired im thinking it my phone. what do i do?
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced.
To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
May 07, 2011 | Cell Phones
I plug my phone into the charger and it won't charge.. it sometimes charges but I have to keep turning it off and on and taking the battery out and when it does charge I can't use it while charging or it...
this problem could be a few things......either the phone jack where you plug it in to charge it- is loose....not soldered good enough inside the phone......or......the plug from the charger is bad...intermittant connection.........or........the battery in your phone is defective so instead of charging normally, it will only charge slightly until the phone says that there's a problem with the battery, so it will stop charging because it is trying to charge a bad battery....try to change the battery first with a new one....if that doesn't work then the first 2 faults that i mentioned would probably be the cause......of course you can always have the plug and jack on the phone checked first before you buy a new battery...it's up to you which one you want to try first.....good luck
Dec 04, 2010 | LG Ally Cell Phone
When I plug in a charger the phone comes on. How do I charge the phone with the power off?
After the phone has turned on when you plug it in, you can turn it off. So, plug in the charger, the phone will start charging and turn on. You can then leave the charger plugged in, but just turn the phone off and leave it charging.
Sep 04, 2010 | Cell Phones
My phone won't charge. I have plugged it into a
switch charger to different wall outlet, turn off phone, and let it charge completely before using again.
Mar 23, 2010 | Motorola Mobility W375 Cellular Phone
I bought a LG enve2 phone from this lady. When I went to have my number changed to that phone or activate it it still shows that phone on her account. I know she had a new phone. What do I do?
boo_walker,
You need to make contact with your service provider. The issue you're experiencing is an internal issue that has to be corrected by your service provider.
If you have proof of purchase, this is where it will come on in handy.
If not, you may have issues.
Apr 11, 2009 | LG enV VX9900 Cellular Phone
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
My LG Enve2 cell phone
Go to messaging; highlight New Msg; then click the settings button.
Highlight TXT Msg and press OK. Highlight Auto View and then choose off and press ok.
Sep 12, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
80 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
