Question about HP LaserJet 6L Printer
I purchased a HP LaserJet 6L around 3 years ago used. I replaced the rollers, and the whole front panel to the printer (sensor tabs were broke). All told, I still got the printer for a steal. It has ran fine for about three years, but here recently, it has started to make a high-pitched noise, and then it only prints lines on the paper. At first, it was only doing this intermttently, but now it doesn't even print at all, and makes the nerve-racking noise everytime I try to print. I replaced the toner cartridge, but it did not help. Even when I turn the printer on and off at initial start-up it still makes the noise. I am ready to take this baby apart again, but if it is either an easy fix, or not fixable, I don't want to waste my time or ruin it any further.
vijay
  • 27 Answers
SOURCE: HP laserjet 6L
Get it cleaned in paper sensor area and check up the drivers as well as data cable which connects, the pc and printer. Change the data cable if necessary. Give me feedback so that may be some more help can be provided.
Posted on Mar 12, 2007
SOURCE: HP 2600n crackling noise at top feed - paper creased
If you are good at mathematics, maybe you' ll see its better to buy a new, exactly the same printer. Take the price of four new cartridges and add the price of a new fuser. Now see if this price is lower than the price of a completely new printer with new cartridges and a new fuser (and all the other new parts). You' ll be suprised! (At least I was)
Posted on Jan 11, 2008
  • 54 Answers
SOURCE: My HP Laserjet 1000 printer
Cleaned the paper pickup unit gear & sensor, your problem will solve.
Thanks.
Posted on Mar 21, 2008
leroyal
  • 2120 Answers
SOURCE: HP 5L printer Paper advance
Parts are no longer available. You might be able to clean the feed roller by removing the toner cartridge and cleaning the gray roller with isoprpyl alcohone.
Posted on Jan 05, 2009
Dadofmykids
  • 25 Answers
SOURCE: HP LaserJet 1600 printing 2 lines on paper, Uneven but straight.
If the line is one specific color, then change the corresponding toner cartridge. (You may be able to see the line on the drum in the toner cartridge.) If the line is a mix of colors, then it is probably either the transfer belt or the fuser. In either case, you could replace the whole printer for about the same cost as repair.
Posted on Apr 08, 2009
HP Laser 6L - Printer makes a squealing noise but does not advance the paper to complete the print.
Old age printer, it needs to replace feed roller assm,pick up roller & separation pad to avoid pickup issues.must be replace these item at a time to avoid tension.
Sep 23, 2011 | HP LaserJet 6L Printer
HP Laserjet 6L Dark Printing
Check your Toner, and also the thermal roller of the printer..
Thank you
May 29, 2008 | HP LaserJet 6L Printer
Hi, I have a HP Laserjet 6L. I recently made the mistake of pulling a paper jam out incorrectly, I pulled the paper out from the paper feed tray rather than pulling it out from inside once the toner...
One thing pl understand this is old printer, while handling you should be carefully, parts are became delicate because of old age.check that paper pick up roller surface got smoothness or dirty, first clean with wet cloth surface of the roller & check, even its not picking up replace both pickup roller & separation pad.best of luck..Vinay.
Sep 05, 2011 | HP LaserJet 6L Printer
Error 59.99 for HP laserjet 3550
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 16, 2011 | HP Color Laserjet 3550 Printer
Printer does not give test page print
Check the right corner of the cover,you will see a pointing plastic touching the sensor,check if its broken then replace it,if you cant,then you need to replace the whole cover,,,
Apr 16, 2010 | HP LaserJet 6L Printer
Tray 2 won't feed, grab, or pick up paper
Try stretching the springs under the cassette lift plate to put more tension on the plate.
Take out the trays, lift the main body off of tray 3, remove the toner cartridge then turn the machine upside down.
Check to see if the feed roller shaft does not have a broken tab and that the roller has good tread on it.
As for tray 3, i've had lots of problems with the gears wearing down their shafts, no replacement parts available for tray 3.
You would have to buy a whole new tray 3 assembly.
Jun 10, 2009 | HP LaserJet 1320 Printer
I can't find hp lasertjet 6l on my choices of printers in XP
Have you installed the printer so Windows can print to it? Support for the HP LaserJet 6L is native to XP, so you don't need any special drivers. Just pick "add printer" from the "printers" control panel icon, select HP from the list of manufacturers, and then pick the LaserJet 6L.
If this solution is what you needed, please take a moment to rate it. If you still need help, please post a followup comment comment before giving a negative rating. Thanks for asking here!
Feb 23, 2009 | HP LaserJet 6L Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
HP laserJet 6L printer making noise/not printing correctly
The problem with the screeching sound and horizontal lines printing is no lubricant for a small motor, not the main motor. To fix this problem, download the service manual which shows how to remove the case. You’ll need a phillips screwdriver and some machine oil or something similar to Z-Max. When the printer is apart and you’re facing it, on top there’s a compartment with a metal cover plate (shield) held by two screws. To the left is a spring loaded switching system that rocks into position when it’s called, and presses on the tab of a leaf switch. With the printer plugged up, you can press on the leaf switch which will engage the printers system, causing the printer to attempt printing. During this you’ll hear the screeching sound you’re describing. This is your test procedure during this repair. Next, notice the two multi-wire connectors at each end of the compartment. One bundle runs across the top of the compartment and connects on the other side. Remove both connectors and the two screws that hold down the shield; one holds down a metal pressure tab, also to be removed. This releases the shield exposing a small circuit board that has a control IC and a small motor. Three screws holds this circuit board to the printers plastic casing. Taking care not to handle the circuit traces (IC Static Protection Protocols), remove the screws and remove of the board. On this board is a small motor with it’s flywheel held down by a square weight and a pressure tab. Remove the top tab and the weight, turn the plastic guide to the side, and lift the flywheel away from the motor. Apply the lubricant to the shaft of the flywheel and reassemble the system. Try your switch test. Chances are, it’ll work without all that screeching. If you get that far, trust me, it’ll print. The "finge"
Sep 27, 2008 | Office Equipment & Supplies
HP LaserJet 6L Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
